Create a F1 class
Old 09-11-2003 | 04:51 PM
TYPHOON's Avatar
Create a F1 class
If you could write the rule book for F1 what would it be?
Lets start with this
1) X dimension stays the same
2) Exhaust stays the same (elbow tops or 525 headers) wet.
3) Drives, XR only
4) Weight, 4700 lbs everybody
5) Motor 500 EFI or 496 same HP.
or
525EFI and Vortec
Mad Dog
TYPHOON is offline
Old 09-11-2003 | 05:50 PM
THAT SOUNDS LIKE A GOOD STARTING SPOT RANDY, NOW IF WE COULD ONLY GET IT DONE.
KEVIN
RADIOACTIVE is offline
Old 09-11-2003 | 06:47 PM
TYPHOON's Avatar
Kevin, please call the F1 teams in the GL series and have them write what they want in our class. If there is no input then there should be no complaining at all.
MD
TYPHOON is offline
Old 09-11-2003 | 07:45 PM
one weight, one engine, one drive,
boat weight 4800lbs
something with 500hp
bravo drive
BC F1-90 is offline
Old 09-11-2003 | 08:02 PM
fastedy's Avatar
*one weight, one engine, one drive,
*47 to 4800 lbs
*bravo drive, standard lower, everybody has one, the sport master is junk if you ask me, it's design for boats over 90
*475 to 500 hp
in relation to another thread, why does a 30' boat with a canopy in SVL weight 4750 but in factory 1 a 30' boat has to weigh 5325 with out a canopy, kinda makes you go hummmm.
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 09-11-2003 | 09:24 PM
eddie,
preach it brother, i am with you not against you!!!!!
one weight, one engine, one bravo!!!!!!
bc
BC F1-90 is offline
Old 09-11-2003 | 09:58 PM
some boats dont agree well with sportmasters Randy some do
F1-00 Racing is offline
Old 09-12-2003 | 02:51 AM
Peconic's Avatar
One engine, one weight, one drive, Trent.
Peconic is offline
Old 09-12-2003 | 07:08 AM
one engine, one weight, bravo drive
ScottB is offline
Old 09-12-2003 | 11:05 AM
TYPHOON's Avatar
Ok I will edit the sports master out and weight the same. I will change it to XR only. What else?
MD
TYPHOON is offline
