Tec help please.
Old 10-11-2004 | 12:14 PM
TYPHOON's Avatar
Thumbs down Tec help please.
Found out why we over heated the SVL Typhoon on Sun. race. My water hose from the drive to the gimbal kinked and cut off the water flow to the motor. This has happened to me in the past and Im sick of it. What have others done to stop this from happening? In spec racing we need to keep the water pickup on the drive. HELP
MD
TYPHOON is offline
Old 10-11-2004 | 12:43 PM
Ron P's Avatar
Enjoy the show
Default Re: Tec help please.
Stop turning left .
Ron P is offline
Old 10-11-2004 | 01:00 PM
Wazzup Racing's Avatar
Registered User
I know a secret na na na na na. call me
Wazzup Racing is offline
Old 10-11-2004 | 01:10 PM
sounds like when the plastic insert got installed in the hose on the bell housing end that swells the hose to the housing, that the hose did not get held firmly from turning while screwing in the insert.
proboat-wes is offline
Old 10-11-2004 | 01:41 PM
David's Avatar
I believe if the piece of hose is a bit too long, it will also do the same thing.
David is offline
Old 10-11-2004 | 01:50 PM
Registered User
Randy we use a different quality hose that will not kink
Old 10-11-2004 | 02:44 PM
DanB's Avatar
Charter Member #71
Use a hose that has the wire reinforcing inside on any hose that sucks water. It will have a rough outside surface. Any boat parts place sells it.
Dan
DanB is offline
Old 10-11-2004 | 03:01 PM
Ryan Beckley's Avatar
Racer
Racer
Put the BEER down and use your other hand to make sure the hose doesn't kink while installing.
Ryan Beckley is offline
Old 10-11-2004 | 03:02 PM
Ted G's Avatar
Also make sure you dont have any debris left in the drive passages, usually that starts them collapsing in the first place. And with all the mulching you were doing yesterday there could be all sorts of stuff in there.
www.cbpba.com
Ted G is offline
Q80
Prop Talk
1
04-25-2008 12:03 PM
BOBCATMATHEWS
08-27-2007 08:18 AM
Jassman
08-22-2007 09:49 AM
muffin
04-06-2005 01:06 PM
Spectre Man
03-25-2004 01:23 PM
