Go Back  Offshoreonly.com > General Discussion > Offshoreonly Industry News
HepcomotionŽ Expands Precision Ring And Track Motion Options >
Hepcomotion? Expands Precision Ring And Track Motion Options
Old 10-28-2010 | 05:13 PM
KennyOffShore's Avatar
Administrators
Default HepcomotionŽ Expands Precision Ring And Track Motion Options
Bishop-Wisecarver Corporation, woman-owned manufacturer of the original DualVeeŽ guide wheel and industry leader in guided motion technology, announces the availability of the recently revised HepcoMotion Precision Ring Track PRT2 system, an even more comprehensive range of ring slides, ring segments, bearings and ancillary components to suit the majority of rotary and track system applications that allow for imaginative and highly reliable technical solutions to be engineered.
The PRT product line, now available in stainless steel as standard, includes a wider range of sizes with lower and higher load capacities. This friction-free, debris-tolerant system also includes several new options which comprise of increased bearing and lubricator sizes, floating bearings, fixed center carriages with clamping brake, continuous bleed lubrication to reduce downtime, and the availability of pinions.
The extensive selection of ring slide types - double edged, single edged, internal/external vees, gear cut or plain - in various diameters, are available in both steel and stainless steel with hardened vee edges for maximum wear resistance. This will provide circular motion control at the edge where it is needed and a large hollow center to accommodate other components, services and even people as in the case of an MRI scanner. Track systems can also be combined with ring segments to create virtually any shape.
Five sizes of bearings are available in a variety of formats in both twin and double row configurations to suit most design requirements. The special raceway conformity and low radial clearance make these bearings specifically suited to ring slide applications. All are lubricated for life internally and are available with metal shields to prevent the ingress of liquids and debris.
Turntable applications are now possible with the addition of precision ground ring discs, providing large precision mounting surfaces that can be easily customized to accommodate a customer's components.
"Every product sector of PRT2 including rings, bearings, track lubrication, and carriage systems has been expanded by additional features and options, allowing our customers to critically value engineer their customized solutions", says Nigel Watson, Engineering Manager at Bishop-Wisecarver. "The extended hardware options of PRT2 keep Bishop-Wisecarver on the leading edge of rotary motion technology".
To learn more about PRT2's extensive range options and upgrades, and information about Bishop-Wisecarver, visit www.bwc.com. For live news and updates, follow Bishop-Wisecarver online at www.twitter.com/bwcnews.
KennyOffShore is offline
HTML code is On
