GPS Pelican Box
Old 05-26-2008 | 09:18 AM
Question GPS Pelican Box
HELP!! How do you get your GPS power and antenna wires into the pelican box and keep the box waterproof?? Anyone have a picture?? Thanks Michael
GoFastSonic is offline
Old 05-26-2008 | 10:57 AM
Billy Martin's Avatar
We Drilled a small hole in ours and Bungied it under the deck behind the dash. You could GE Seal it once you feed the wire but ours hasnt been and knock on wood, havent gotten wet yet. Hope it helps Good Luck!
Jr.
Billy Martin is offline
Old 05-26-2008 | 04:48 PM
Thats what I was thinking but the gps unit looks like it does not like water at all
Old 05-28-2008 | 05:34 AM
Drill 2 holes in the side of the pelican box, run the gps antenna wire through one hole and run the ignition/power wire through the other hole and seal it up with goop on the inside and outside of the hole. The pelican box has an air breather in the box for condensation built in. You definitly do not want to keep the holes not sealed as the connectors will rust on you if you don't. Hope this helps, Al
32tempest is offline
Old 05-28-2008 | 09:12 AM
Thanks Al!!!
tgersx
3
06-09-2007 09:27 AM
tgersx
06-08-2007 05:18 PM
Andy Buzz
04-08-2003 10:00 PM
BGIII
09-17-2002 08:20 PM
kook
05-11-2002 10:32 AM
