Go Back  Offshoreonly.com > Race Talk > OPA/The Jersey Boyz
Just how much damage was done at O.C.   ......... >
Old 06-14-2012 | 09:08 AM
2 Trick Rick's Avatar
Racer
Default Just how much damage was done at O.C. .........
Lots more than we thought originally
All the damaged bulk heads, broken core and cracked cloth had to be removed and new core is cut and ready to go back in..
Attached Thumbnails Just how much damage was done at O.C.   .........-oc1fix_020.jpg
2 Trick Rick is offline
Old 06-14-2012 | 11:39 AM
We ripped a prop hub apart, blew a drive, and had a valve cover come loose
We feel the pain. Good Luck
Ntrsspray is offline
Old 06-14-2012 | 10:48 PM
TeamSaris's Avatar
Driver-441
Racer
We ran flawlessly
TeamSaris is offline
Old 06-15-2012 | 08:46 AM
blew the engine hatch a apart...shoulda just let it go
main harness to the helm came outta all the ties along the gunnel too, but not sure how long its been like that...haha
Lefty555 is offline
Old 06-18-2012 | 08:38 AM
gary cook's Avatar
Racer
Racer
I cant believe you broke stuff on your boat because you are so easy on her
gary cook is offline
Old 06-18-2012 | 09:38 AM
Racer
FRIDAY: 8pm - 1:00am Friday night we embedded the core in 2 layers of chop, let dry, filled all the small gaps with "gunk" and covered the care with a 2ft x 6.5ft sheet of 1708
SATURDAY: 9:00 am - 1:00am Sanded area and applied another sheet of 1708 over cored are (both sides) and attaced first bulk head. Than moved back to attach 2nd bulk head.. all gunked in than both sides and tops were attached with 12inch sheets of 1708
SUNDAY: 9:30am - 6:00pm : Finished last two bulk heads and DONE.. The whole repair was done with "PFM" to ensure that it will hold together for the rest of the season.
Off to paint..
Sorry no in between pics as once Gary and I started we just keep going with no breaks.
Attached Thumbnails Just how much damage was done at O.C.   .........-oc1fix_021.jpg
Old 06-18-2012 | 10:17 PM
TeamSaris's Avatar
Driver-441
Racer
Originally Posted by fast fun 2
We ran flawlessly
Nevermind
Old 06-22-2012 | 09:34 PM
fastedy's Avatar
trim pump jumped out of bracket and broke power wire, thats all, reason for not having left trim tab last 3 laps
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 06-24-2012 | 12:40 PM
Well the work paid off first place finish. Great race look liked it ran great. Great job
wheelman is offline
