A hull with that power to size/weight ratio that runs that aired out must have props that are balanced/blueprinted. Not sure if any of you have tried that at all. A stock mercury 'lab' cleaver (before the CNC props) will not be properly balanced. Unbalanced props will cause the boat to go into a chine walk if it starts porpoising at a high rate speed because the footprint on the boat is smaller at 110+ and unbalanced props may cause the boat to pull to one side, then it will toss to the other side=violent chine/death walk.
Originally Posted by JoeD
(Post 2261799)
Yup I figured they were yours,how are you making out with the 5 blades he told me about.
LINKS What was your buddys name? What size and pitch did he tell me you were testing and what were the before and after numbers ? [email protected] |
Now I remember Glen------Good Luck at "ROCK THE BAY" and I hope your boat runs great for you, we will attend the offshore races here in PT. Pleasant this weekend.
4 blades seems to be faster up top.
Originally Posted by Pro1
(Post 2262813)
(Post 2262290)
Originally Posted by 42MTI
(Post 2260154)
I did ride once in a quadstep 37, and it rode much better that the single step.
Media Master, a cut down 37' single step with 6's and big power doesn't porpoise or chine walk. MTM, also a single step runs over 100 mph and no chine walk or porpoise. (bravos) I've been on it a dozen times... pulls real hard. There was also another 37' with 1200's on #5's...forgot the name, it's in Long Island... no porpoise or chine walk... single step. |
Originally Posted by Panther
(Post 2269956)
That's interesting, I heard the opposite... And also thought the reason they stopped making the quad step 37's was due to handling issues/roll overs/spins??
Media Master, a cut down 37' single step with 6's and big power doesn't porpoise or chine walk. MTM, also a single step runs over 100 mph and no chine walk or porpoise. (bravos) I've been on it a dozen times... pulls real hard. There was also another 37' with 1200's on #5's...forgot the name, it's in Long Island... no porpoise or chine walk... single step. My understanding is that they quit making the quad step for the same reasons. Which would also stand to reason why it rode flatter. Flatter, meaning less skeg in the water, especially in turns. It was a great ride though, in fact I tried to buy one after the poker run. |
(Post 2270074)
I have also ridden in other 37 single steps that rode very well. I think Lets Rock just had a very high x-dimension. Because it was very fast for 900's, just not the most stable boat I have ridden it.
Sounds like a great ride, as was the one I rode in.
| All times are GMT -5. The time now is 08:05 AM. |
