Picked up a 28 >
Picked up a 28
Picked up a 28
Old 08-21-2005 | 06:17 PM
Turbojack's Avatar
Default Re: Picked up a 28
The size of the bypass hole regulates the total amount of boost. The bigger the hole the less boost the turbo builds because more of the exhaust is bypassing the Turbo. You can install waste gates between the manifolds & the turbo to limit boost. I had a dial on my dash that I could use to crank boost down to a min of 5psi or a max of 15psi. Waste gates also let you build boost sooner and then start bypassing to keep the boost at the preset amount. The determining factor as to how much boost is determined by when the motor goes into detentation. When detonation starts the motor becomes a boat anchor real quick. Do you know what the static compression is? The lower the static compression the more boost you can run.
Turbojack is offline
Old 08-22-2005 | 02:41 PM
littledcsrodshop's Avatar
I have not dug into finding out the static compression yet.
However I need to correct myself on the cubic inches it is not
468 it is actually 511 cubic inches. The heads are worked 990's with 2.20 & 1.90 valves. Later, Scott
littledcsrodshop is offline
Old 08-22-2005 | 09:55 PM
IRONMAN's Avatar
Nice 28 ,I hope there are more like that around it is exactly what I am looking for but with a TRS or alpha. Good luck with the project.
IRONMAN is offline
Old 08-23-2005 | 09:54 AM
Hey Scott,
I sent you an email.
-Al
BajaFresh is offline
BLOWN85
Velocity
0
09-05-2007 09:20 PM
The Menace
25
06-28-2007 06:50 PM
pshannon
03-30-2006 07:14 PM
GATORONE
Fountain
15
04-11-2002 11:25 PM
