Re: Prop for a 24
Ironman -
I had been running the 26P Bravo, until my low oil pressure issue. 76.8 MPH GPS was the best so far. My new engine will hopefully get me closer to 90 MPH. Then I'll need the 28P or a 30P. :evilb: |
Re: Prop for a 24
What are you going for in the new engine, or is that top secret?? I am going to do new power once I can sell my 24.. Chris
Re: Prop for a 24
Originally Posted by IRONMAN
Kirk what is working best on your 28 now?
Re: Prop for a 24
Hey Fellows,
I had a chance to try T-Mone's labbed 27p Mirage plus this past Friday... :cool: My boat was faster on top by 1.5-2mph but the boat did not handle nearly as well as with my Bravo 1. Cruise speed at 3500rpm was down about 5mph also. IMO, the added speed is not worth the handling deficiencies with the Mirage +... Has anyone ever tried a Hydro QIV-X 4 blade? |
Re: Prop for a 24
Kirk, what kind of pwr pushed the 28 to 76.8 and what kind of rpm
Tom |
Re: Prop for a 24
638 HP at 5600 RPM I believe. I have to verify the RPM.
My new engine plans have changed several times. First I was going with a 700+ HP naturally aspirated EFI Engine, now I bought an M-3 with large intercooler and might build a 540 fuel injected with the M-3, should be 800+ HP at 6 PSI of boost. There will be no engine if I don't figure out my drive issue first. An XR wll not last real long behind that power and I'm not taking the chance. Boating season is too short here in IL. |
Re: Prop for a 24
Originally Posted by noboat
If you're X is at 17" the and you cruise 90% of the time I would try a Bravo 1. What rpm should your motor run at WFO?
Re: Prop for a 24
I thought you were a konrad dealer...
you cant be seen driving around w/ a merc drive! :eek: |
Re: Prop for a 24
Bravo's - 24P, 26P, (2) 28P all
Originally Posted by Pantera28-650HP
I have the following sitting on my shelf in my garage:
RH Rotation Mirage Plus - 23P, 25P, 27P all RH Rotation Mirage - 29P RH Rotation Stern Driver - 28P RH Rotation For the cost of shipping, you are welcome to try any of them until you figure it out. Sincerely, That is so cool of you to offer that. Right now I'm so slammed moving out of one of the largest privet estates in Newport RI that I worked and lived at for 20 years as a caretaker that had a great heated garage. And now I'm trying to find places for all my stuff. My motor was built 2 years ago and I just want to break it in and maybe go for a short ride before winter. Then it will half to be out side. Maybe the Bravo 24p would be a good place to start? Thanks Todd Kirk |
Re: Prop for a 24
If you are really at 500 hp and need to run at 5000 rpm I would say the 26 Bravo would be the best starting point.
| All times are GMT -5. The time now is 09:49 AM. |
