Estimated Speed >
Estimated Speed
Estimated Speed
Old 05-24-2010 | 06:24 PM
Courtholl's Avatar
Default Estimated Speed
Some may recall that I had an engine block crack on me the winter of 2008/2009. It was due to the people who were suppose to winterize our boat, did not. Anyway, long storry short, I finally received a settlement check.
I am having an engine built and it should put out about 450-475 hp. It is a 454 that is bored and strocked to be a 496, etc. port work, larger intake and carb, cam work, etc. It will be dynoed, etc. The builder thinks he will be able to get 475 HP out of it. I am not sure what the HP of my past engine was, but we ran about 72 MPH at 4800 RPMs. Had a smaller intake and carb, normal port work, so was not able to pull anymore out of it (had to trim the hell out of it to get it there).
I have an 89 24. With 475 HP, what type of speeds might we be looking at?
Courtholl is offline
Old 05-24-2010 | 07:51 PM
onesickpantera's Avatar
73-75 mph
onesickpantera is offline
Old 05-25-2010 | 08:07 AM
rchevelle71's Avatar
I think you may gain a few MPH, but it will take signifigant gains in HP to get a 24 over 80.
rchevelle71 is offline
Old 05-25-2010 | 02:50 PM
Stormrider's Avatar
JC Performance Engines
560hp ran 75 w/ me when new...
now does 78-79 w/ ziemer... maybe better.
Stormrider is offline
Old 05-25-2010 | 06:34 PM
I do 83-84 GPS with 600hp / TRS and you beter know how to drive ! Wife dosen't like it ! LOL !
OCCJoe is offline
Old 05-26-2010 | 12:28 PM
fantastixvoyage's Avatar
Already start on the build? I have a 510" that made 535hp/570ftlb on the dyno if you haven't pulled the trigger yet. Same motor pushed my 29' to nearly 80.
fantastixvoyage is offline
Old 05-26-2010 | 12:40 PM
475hp out of a 496 stroker can almost be built by accident. With the right cam and some head porting, 500hp+ is fairly easy to make.
Griff is offline
Old 05-27-2010 | 05:31 PM
Courtholl's Avatar
What are the hours on it and what you be looking to get out of it?
