Windscreen on a 28'...who's got a pattern? >
Old 02-03-2011 | 05:33 PM
Originally Posted by Viperchad
Yes. What he said. Griff do u still have those other wind screens?
What? We heat form and bend Lexan all the time. I'll have pics in the summer.
VelocityRick is offline
Old 02-03-2011 | 05:55 PM
I use windaways on my 27 Carrera, instead of clamping brackets
I bolted them in, if I want to remove them it takes about 5 minutes and they are gone. They are about 6" tall and block 70% of the wind if I stand straight up in bolster (I am 6' tall) and about 80% if I just scooch down in bloster a bit.
Sitting they block almost all the wind.
Eventually I will custom make a taller fairing since mine is so short but for the money you can beat the difference the windaways make.
You can see them on my boat (second and third pic down) in these poker run pics:
http://www.damncarrera.com/pkrunjuly2010.jpg
HTRDLNCN is offline
Old 02-03-2011 | 08:15 PM
Originally Posted by hotjava66
I have a set of flip-ups like shown in Griff's picture. If I get something else made you can have them, might be spring before I get it done though.
Thanks brother. Much appreciated
Viperchad is offline
Old 02-04-2011 | 01:53 AM
They were on the boat when I sold it to Sean. Duunoit owns it now. I don't know if anybody makes them anymore. Some used ones do pop up in the swap shop every now and then.
Griff is offline
Old 02-04-2011 | 08:04 AM
I have the same ones as Griff's pictures on my AT and like them except that I would like to lock them down when I don't want them popping up with 50 mph wind. I notice in Griff's picture, there appears to be a latch or something in the center that holds them down when they are not wanted. Can someone explain what this is? If possible a closer view would be greatly appreciated.
HavinATantrum is offline
Old 02-04-2011 | 12:29 PM
I used the same small plastic latch things that are used to hold in window screens and some plastic spacers.
Griff is offline
Old 02-04-2011 | 01:17 PM
That's what it looked like but I couldn't tell for sure. Did they seem to work out ok? I was thinking that I wanted something that was hidden like a snap or something like that under the top cover but at this point your solution seems to be the best. Thanks
Old 02-04-2011 | 01:21 PM
So far windaways and finneys are the only two retail sites I see. Does anyone have info on the manufactorer of the "flip up style"??
Old 02-04-2011 | 02:32 PM
Don't know who made them, heard livorsi but not sure. I do know that Brian Tillett "Sydwayz" on the Active Thunder site said he has a few left at the factory and wanted to sell them just a month or so ago. If you look around on that site you will find him easily, hope this helps.
Old 02-05-2011 | 01:49 AM
Yep, they worked fine. You could control the tension on them by tightening the screw to keep them from moving while underway.
I maybe had to give the screw a 1/4 turn a couple times a Summer to keep them tight.
I don't think anybody is actually making them anymore.
Griff is offline
