Any interest in a 3man 24' pantera?
5 Attachment(s)
Same old story - work and life taking up too much time so something has to go.
Boat is the old No Limits raceboat raced by MER back in the day. Great boat with a TON of extra structural work done over the years. Think mini-Apache. Will be listing it shortly but figured I'd give you guys first crack at it. Boat is very solid just a couple cosmetic items. Boat has the following: 24' raceboat add'l bulkhead in the bow ballast tank add'l stringer supports TRS drive w/nosecone BW trans bellhousing w/cooler & coupler dual ram steering with billet filter large K-planes latham controls front and rear mounts merc racing trim pumps (#6 style) Also purchased some additional items: -hydraulic helm from Imco -9pin harness -dash harness -Gaffrig race edition guages - carbon fiber (black) face -Lonseal flooring -TRS transom assembly - spare (current one has a repaired gimbal ring) Also, swapped out the junk trailer for a clean Eagle black steel tandem trailer setup for this hull. No motor but do a have a 540hp motor I could sell. Built to handle the big stuff so this boat would be a blast whether as a raceboat or pleasure. A bit tough to price as there's not much out there to compare it to. Asking $13,500 minus motor Open to offers. Pics are a bit old but they give you an idea.... |
3 Attachment(s)
more
Man!
I like it... beefy looking for sure:eek: Going to make someone a great bulletproof hull. |
Sure is! Plans were to run in 5 or 6 since it is a perfect boat for that. Can run hard without having to worry about the boat coming apart. Would make a fun day boat too for the same reason. I'll try to post a video of it running. Ran very hooked up and flat with this configuration.
Also very easy to make a sitdown as well if someone prefers that route.
Do you have a shot of the dash configuration
1 Attachment(s)
Ask and you shall receive... Old pic with the original dash but gives an idea of layout. Not currently setup for single person operation but could easily be converted to single or dual setup.
Wow, that looks bulletproof...great condition!
Originally Posted by modvp
(Post 3418781)
If I could sell it quick I'll take $11,500 as it sits. Hell I'll even toss in everything but the guages. |
Here is the swap shop ad, going in classifieds on multiple sites over the weekend.
http://www.offshoreonly.com/forums/s...us-engine.html |
Are you going to race the Phantom in Class 5?
waterboy - not too likely. I'll be looking to sell that one once the pantera is gone and I find some time to finish it.
I may however run a 25 Powerplay in at least St. Clair but have to wait and see how the boat runs. Should be a great turnout in class 5 and 6 this year for sure. |
| All times are GMT -5. The time now is 02:57 PM. |
