Lake Cumberland Poker Run
#41
#45
Tim how did you like that scum line. That water was nasty. I tried to wipe it off when I took it out and it would not come off, at home tried soap and water and that would not work either. I had to use this awesome stuff and that worked well.
#48
took an hour to get the boat clean. and i waxed it before i left for the weekend. heavy car wash soap and alot of elbow grease got it clean. not somewhere i would wanna keep my boat in all the time spend more time cleaning it than using it
#50
Yeh, I was in harmon....I know several high dollar boats that stay down there and the rings aren't always that bad. If you tie up to a houseboat it helps to tie up on the left side towards the front so you are away from where the rear exhaust dumps.... I have fought it every year and it's not enough to keep me away from this run.
