Originally Posted by paul buckner
(Post 3564673)
That is another way of doing it as Bullet says ,water presure fills it up very fast .there is norm an over flow fitting at the side from the top of the tank for when the tank is full , just about every ski boat here in the uk has one like this .and gravaty drain which works of a three way valve .pipe size is norm 0ne inch bore. regards paul
I did get side tracked looking at ribs, and reading petrol...cheers....cheerio.....kilometers..... What are you guys talking about??:lolhit: Mike |
Hi Mike go to the (Technical Question & A section ) its the first page ,14 posts down , water pickup Question. . As for wot are they talking about Q some times i dont even understand wot they are talking about ,tell me where you read it and i will see if i can translate for you LOL regards paul
(Post 3565232)
I was looking on page 14!!!!! For anybody else its boatmaddotcom. Like a brit oso. Very intetesting, never been before Thanks P |
Wicked Won also had a fitting on the k-plane to fill the ballast tank(s).
Originally Posted by scarab63
(Post 3565251)
Wow... This just galvanizes my retardedness!!!I was looking on page 14!!!!! For anybody else its boatmaddotcom.
Like a brit oso. Very intetesting, never been before Thanks P ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!:coolcowboy: ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:drink: |
(Post 3564969)
Paul I took a look where you advised and did a search keying ” ballast ” with no luck!!!!
(Post 3565363)
Translation for ya . GAS ,THANKS .GOODBUY . DISTANCE
Found it so now I can fill it using just water psi while underway. But still thinking ill need a bilge pump to pump out. It doesnt have a bottom / gravity drain. Thanks all. Mike |
just curious if you figured out a way to go with your tank. Also any of you other guys with 500+ hp adding weight to the front of your 24, ballast or lead. JAime
Originally Posted by JAIME
(Post 3611390)
Just curious what the final solution was/is going to be?
Would water pressure alone force water out of a bilge pump outlet, past the bilge pump once the tank filled up? Or would you need a seperate overflow? You would need a breather hose anyhow, so I suppose the breather would double as the overflow.... |
| All times are GMT -5. The time now is 07:05 PM. |
