Originally Posted by tomcei
(Post 3719994)
Get a baby sitter and you and the wife do the run. I plan on taking the wife and kids myself so i will be taking it easy (mostly...lol)
As far as numbers i don't have anything yet. Tonight I found my steering rams leaking and pulled them off. I did have some tuning time with the idle and in gear low speed circuit adjustment. The docks and trailers were giving me fits. It's sweet now. I just fixed the water pressure and have it where I want it. I have 6 hrs on the mtr and drive so I'm ready to let it rip. Once my rams get fixed I will confirm my water temp on the chiller under boost and if good then I will spill some beans on the performance. It ran right at 80 with the last mtr. this one will do that fo sho I just rebuilt a motor for a 28'. Last year at the end of the year the owner put an SCX on it with the 1300 lower unit. The boat lost 10 mph (72mph). With a Bravo the boat always ran right around 80 mph (800 hp). This year, I pulled the SCX lower off and bolted an XR Lower on it and the boat magically picked up 11mph. The 1 extra mph was the fresh engine matched to a better camshaft. Point being, he lost 10 mph with the SCX and 2" lower. We're not sure where to go with the project at this point. Either put a 2" spacer on with the SCX, Put an SC lower on it or, put an XR Lower on it. |
Well,..... I knew that I would loose speed with the SCX for sure. My objective was to build a reliable quick boat vs. a fast boat. I prefer handling ruff water with excellent throttle response over flat out speed. I also didn't want to worry about a weak link and blow out a drive. That being said, I have great acceleration with marginal speed. I run a tick over 80 @ 5k. She gets there quickly using a 5 blade 30 pitch maximus. I had the prop worked to tweak the handling and that turned out great. I believe I have many mph left on the table for sure. I haven't done much with it because most of my running is with my kids and we average 50-60 mph running around. It is a blast to push the stick forward and snap to 80. So much so that I really don't have a huge desire to focus on the top speed. I spoke with a few of the guys that use to be on the board about their set ups. 1000 hp in the Mig and 1000 hp in b -stubs old boat. Those guys were running the xr stlye drives and were doing mid 90's ,mph. with props raised up high. Loose = fast. Their slips were very high so they ran 6 blade props. The mig was a really light lay up and Bstubbs was a full pleasure. Both boats had notched transoms. I'm not into dancing around loose and fast in ruff water with my kids, too risky. ( maybe alone). I do love big air and ruff water just not running on the ragged edge of....lol
I'll give you a ring today and go over some details. If I found a deal on an xr or sc lower I would try it but after almost 12 years of a Pantera love affair I'm am getting a wandering eye. |
Thanks. Look forward to chatting.
Originally Posted by Panther
(Post 4454611)
Curious to know how everything turned out for you.
| All times are GMT -5. The time now is 07:41 PM. |
