Merc Integrated Transom System (ITS) on a 24 Pantera? >
Old 10-13-2014 | 07:13 PM
Sorry ive been absent guys, I was rearended in my car while I was stopped in traffic at a red light a few days back, so I'm a bit slow going right now. Also my OSO membership lapsed the last few days so I just renewed it, just now.
Originally Posted by paul buckner
Just what you are looking for in the swap shap. Page 2
Yes Paul, thank you I saw that, he sent me pics already and I believe Pantera572 got his ITS form the same guy.
Ive been playing around with the idea on what to do with this setup. The current alpha drive has a nosecone on it, it had it when I purchased the boat. The boat runs and drives great as is, just wish it had more on the top end. The boat used to have a built up sbc in it that had quite a bit more hp than the current stock 260hp V8.
If I build up the current motor a bit (heads, cam, intake, carb) to get close to 350hp I can leave the current alpha setup as long as i am easy on it. If the boat will pull 60 mph with a setup like this i would be happy. Currently I can get it to 52.5 mph on gps light on fuel and just me in the boat.
OR...
I know where I can source a brand new fully balanced short block consisting of Dart Little M 4.155 Bore Block, Dart Pro1 heads, fully forged rotating assembly, H-beam rods, forged flat tops at a great price... should make a great running 406 sbc! But... then I would need to update the drive, get the hydraulic steering, etc... that's why I was considering the Merc ITS system as it has a nice and clean installation. But this will cost me some $$$ and the ITS will look a bit out of place on my old school boat.Plus I was thinking about the drive height issue even before you guys brought that up, I just didn't know if the bravo swap put the prop deeper in the water. You guys just confirmed that it does. And with the set back I fear it will be too deep in the water and I think a shortie lower will be needed.
Decisions, decisions...
DjMikeyC is offline
Old 10-13-2014 | 08:15 PM
[ATTACH=CONFIG]530993[/ATTACH]
Found a picture! Had a 496HO and Ran 72. I wanted the hydraulic steering and the XR. Makes for a very clean and heavy duty setup for a 24.
Attached Thumbnails Merc Integrated Transom System (ITS) on a 24 Pantera?-pantera8_15_09-012.jpg
Out There is offline
Old 10-14-2014 | 10:26 AM
Wow you are right that is a very clean looking setup!
DjMikeyC is offline
Old 10-14-2014 | 11:57 AM
Ing's Avatar
Ing
Veteran: Marine Corp
Ya that ITS setup is nice with the twin swim steps.
Ing is offline
Old 10-14-2014 | 02:10 PM
Exactly what I was thinking!!! I have the original teak swim steps from my Pantera, but they wont fit with the tabs or iof I added transom mounted steering. If I do the "ITS" I can add steps like these and still get the steering to boot!!!
DjMikeyC is offline
Old 10-14-2014 | 03:51 PM
Stormrider's Avatar
JC Performance Engines
DJ, what's the cost for all this?
Engine?
Exhaust?
Drive?
Stormrider is offline
Old 10-14-2014 | 07:13 PM
Engine?
Exhaust?
Drive?
Ahhh... you know very well its going to cost more than my boats is worth, resale value of the boat will go up with these newer parts but you will never get your money back on them. If I do the ITS drive setup one season and wait until the next to do the rest the hole in my pocket will not be as big. Only thing is as stated earlier, it looks as if a shortie lower will need to be installed... so the ITS setup as purchased will need to be changed. And I doubt the stock lower water pickup XR lower will bring the same price as say a IMCO shortie lower. The plus side is that I will have precise steering for the boat and the drive will most likely never break unless I throw a supercharged bbc in there. Changing to the Merc ITS may be worth doing even if I do nothing else.
My $0.02... don't mess w/ a good thing.
Storm... I wholeheartedly agree with you on this one. Buy doing anything to the setup I can open up a can of worms.
DjMikeyC is offline
Old 10-14-2014 | 08:06 PM
If you want fast and fun at a lower cost. Sell your boat and buy ING's boat.
slpcamaross97 is offline
Old 10-15-2014 | 11:41 AM
And i know someone who would buy your 24 too. And its not me.
Old 10-15-2014 | 01:12 PM
CIG3's Avatar
You could stay with the standard drive length if you plug the transom and recut the hole where it needs to be. The small block should have plenty of room under the hatch. Transom cost would be half of a -2 shorty.
CIG3 is offline
