-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   Alpha SS in a 24? (https://www.offshoreonly.com/forums/pantera/285908-alpha-ss-24-a.html)
DjMikeyC 10-04-2012 01:19 PM
Alpha SS in a 24?
Anyone ever run an Alpha SS in a 24? Thinking about swapping a stock Alpha to an Alpha SS... SBC boat... any one see any issues with this idea?
Stormrider 10-04-2012 02:19 PM
Did you buy that brown boat in NH(?)
vintage chromoly 10-04-2012 06:24 PM
i think the ss is 2 inches shorter. i may be wrong about that but i remember reading that somewhere.
scarab63 10-04-2012 06:54 PM
What about selling both & running a B1?
Drill a couple more holes, add a sea pump & have peace of mind.
Won't raise height or gain speed, but def worth it imo.
There's a B1 on Boston cl for 600$
Tinkerer 10-04-2012 06:55 PM
2 1/2 inches shorter.
CIG3 10-05-2012 08:19 AM
I think it would run pretty good. I've run the ss on a 24 P&D with 375-400HP with no issues. Slow out of the hole and good throttle skill are a requirement. Mine ran upper 60's with that combo with 21 Mirage
Tinkerer 10-05-2012 06:31 PM
Unless you raise your X a Bravo will slow you down and it is a lot heavier. If it was me with experiance in Alpha SS drives - If I had the chance to do it all over again I would have done something different. BUT back in the late 70's there wasn't the options that there are today.
