Sweet Deal on a New Pantera 28 SR.... >
Old 12-20-2012 | 08:36 AM
  #131
ziemer's Avatar
Originally Posted by OL40SVX
...did you watch the races in KW where the boat dominated in rough water?
Yep! And dominated is probably an understatement.
However, the OL 29' and Pantera 28' are two completely different boats.
ziemer is offline
Old 12-20-2012 | 08:45 AM
  #132
[QUOTE=ziemer;3834949
However, the OL 29' and Pantera 28' are two completely different boats. [/QUOTE]
what do you mean by that??
boatnt is offline
Old 12-20-2012 | 02:05 PM
  #133
one is built strong and fast and the other is just built strong
mikebrls is offline
Old 12-20-2012 | 06:12 PM
  #134
What about light? Is there a weight for the Outerlimits?
JAIME is offline
Old 12-20-2012 | 11:05 PM
  #135
4900 lbs . And I'm a fan of both boats but the OL is gonna get on top and ride high and light mostly because of those four giant steps . If you watch Brian's video in Doc Janson's boat it walks back and forth though the entire pokerrun . However if you watch any 28 Pantera in rough or sloppy water they ride straight with no walk ... But the downside is a 525 in a Pantera is a low 80 mph boat but that same power in the 29Sv or SVL is 95 mph .
Its almost seems like there is more than 400 Lbs difference between the two boats ..
The only thing that would prove any difference between the two is if you could watch the OL run at only 80 and then see a 28 Pantera run at 95 .
In the End it's those steps, OL just got it rite ! But then again there's only four splashed and one in production . Time will tell !
OCCJoe is offline
Old 12-20-2012 | 11:23 PM
  #136
Call me ignorant.... but what the hell does SVL stand for...???? Hmmmm...
Pantera28TS is offline
Old 12-21-2012 | 12:20 AM
  #137
SVL Super V Lite ,,,,I think a Super V should be at least 35' . The 29 should be the 29BV for baby V
OCCJoe is offline
Old 12-21-2012 | 06:24 AM
  #138
Another thing that comes to mind is what is the true running length and beam of the 29 OL...?? Not bashing by any means, I love the look and performance... But just trying to compare apples to apples...
Old 12-21-2012 | 07:10 AM
  #139
Default ez
IGNORANT
"Sloppy vagina lips"
Everyone knows that. It's code....
" watch out, I hear that chicks SVL"
OR
"Some people might say the outerlimits 29 runs looser than SVL in the rough."
scarab63 is offline
Old 12-21-2012 | 08:38 AM
  #140
The hull layup is probably more controlled on the Outerlimits also and more consistent from hull to hull.
Interceptor is offline
