-   Pantera (https://www.offshoreonly.com/forums/pantera-39/)
-   -   Trim tab placement on a 24x7 (https://www.offshoreonly.com/forums/pantera/296297-trim-tab-placement-24x7.html)
Boatally Insane 05-13-2013 09:00 PM
I'm in the process of rigging my 24x7 Excalibur and was wondering if it's best to mount the tabs parallel to the hull or the water?
Thanks,
Doug
http://i130.photobucket.com/albums/p...ps8672f0ba.jpg
IRONMAN 05-13-2013 09:22 PM
Is neither an acceptable answer? But seriously I prefer at about 20 - 21 degrees and 1/2 inch above the bottom at the closest point. Remember a trim tab is a rudder if installed at 90 degrees and provides lift only at 0 degrees of deadrise. Most will install them at the same deadrise as the hull but there are many factors to consider.
Griswald 05-13-2013 09:54 PM
How's the build coming Doug?
rchevelle71 05-14-2013 06:34 AM
Right or wrong, mine are parrallel to the hull, and about a half inch up from the bottom as ironman said.
Boatally Insane 05-14-2013 07:59 AM
Slow but steady.. Been slammed at work lately..
I have a little more to do in the bilge and cockpit before it's ready for paint / rigging. Have all the interior. Engine is at the machine shop. Will have to run N/A for a season until I come up with the $$ for the blower but should still be a fun ride. :evilb:
Doug
Boatally Insane 05-14-2013 08:29 AM
Actually I think I like that answer. Maybe accomplish best of both....
Part of my issue is I've never driven or even been in a 24x7 so I don't really know what to expect...
I'm assuming it will be prone to listing at slower speeds because of the narrow beam, and may need help keeping the bow down running in the rough being as light as it is...
Griswald 05-14-2013 01:00 PM
Doug
My motor is out, too. Just wish Dave was still around for the fresh-up.
Mount those tabs parallel with the hull and not horizontally.
tomas_wallin 05-14-2013 02:44 PM
I started this thread a while ago:
http://www.offshoreonly.com/forums/g...orizontal.html
OCCJoe 05-14-2013 03:26 PM
Mine were parallel with the botom and it robbed 5mph off my speed . I pulled the plates off 85 ... I put them back on 80 .. I will never go with the V again . At least pull them up to 21* .
tomas_wallin 05-14-2013 03:33 PM
Sounds like your tabs were mounted too low and always in contact with water, causing drag and maybe even acting as a rocker. Correctly mounted tabs shouldn't rob any speed when in the up position.
Boatally Insane 05-14-2013 06:53 PM
http://www.texasenginemachine.com/ ;)
Boatally Insane 05-14-2013 07:52 PM
Originally Posted by tomas_wallin (Post 3925398)
I had you send me pictures of your transom a while back.. :)
Unfortunately I don't have enough room between my strakes and the drive to mount them quite that low.
However, I just came across a video of my old Checkmate and it would appear the tabs would have no problem reaching the spray coming off the hull even if they're mounted higher..
http://youtu.be/ftkMurA4g_w
TeamSaris 05-14-2013 08:19 PM
Some people love them horizontal...some people, myself included, hate it. You cant extend the length of your boat when they are horizontal, your either up, or causing a serious hook.
tomas_wallin 05-15-2013 01:01 AM
Ah yeah I did!:lolhit:
Isn't your hull similar to the Pantera?!
tomas_wallin 05-15-2013 01:09 AM
This is what my hull look(ed) like:
http://i1291.photobucket.com/albums/...ps2d5a8240.jpg
http://i1291.photobucket.com/albums/...ps63c80b1c.jpg
Griswald 05-15-2013 07:20 AM
Originally Posted by Boatally Insane (Post 3925561)
David Wolff bought all of Dave's equipment and is running the shop out of the same place. I'm good, thanks.
Boatally Insane 05-15-2013 07:41 AM
Yes it is... The Pantera is a splash of the Excalibur...
http://i130.photobucket.com/albums/p...psf2c01051.jpg
How wide are your tabs ?
I'm using 280 K planes which are 14" wide..
If I mount them at the strakes they will interfere with the drive turning...
rchevelle71 05-15-2013 08:29 AM
Can't seem to find any pics of mine on this comp, but will keep looking.
rchevelle71 05-15-2013 08:43 AM
Found a few, but not the greatest as I had to get them off another website I had previously posted them on. A bit different setup than y'all with 400 pounds hanging 2 feet off the back, they do tend to drag a bit:lolhit:
http://i1036.photobucket.com/albums/...ps7531f080.jpg
http://i1036.photobucket.com/albums/...ps0d85fd61.jpg
Boatally Insane 05-15-2013 08:48 AM
I stopped by and talked to Dave as I know he does awesome work, but he isn't equiped to turn a crank and had no interest in porting heads.
I decided to just haul it out to LLano so I could get everything done in one place... Bob at FTM has been using them for years with no issues.. :)
Doug
tomas_wallin 05-15-2013 09:15 AM
My Dana HP900 tabs are according to Dana's website 12" wide x 17" long. I have plenty of space between tabs and drive.
Not the best pic... I'll try and measure later.
http://i1291.photobucket.com/albums/...ps2fb95bec.jpg
OCCJoe 05-15-2013 11:26 AM
Yes it is... The Pantera is a splash of the Excalibur....
technically they are both splashes of the boat the Cuban's designed and raced in the early 70's . So you can't say Pantera is a splash of excalibur . I know somebody that was with Pepe in 79 when he cut a 2x4 and dropped it in the bottom of the hull mold creating the delta pad . But sitting in my shop I have a mold that was made from a excalibur and it has the same delta pad so I would think that's proof that Excalibur spashed Pantera .
Boatally Insane 05-15-2013 01:14 PM
Ok... sorry... I should've said "Yes they ARE similar" I CERTAINLY don't want to start a who copied who argument. I wasn't there so I was just going off information from others...
I've never seen the bottom of a Pantera in person..
Is the pad you're speaking of the same as on my Excalibur which was built in 1979 ? :whistle:
http://i130.photobucket.com/albums/p...r/P4280040.jpg
vintage chromoly 05-15-2013 01:42 PM
Well, I have hull #2 and it's a '77' and it has a delta pad so your dude's memory must be rusty. When did bill farmer lay up the first excaliber 24-7?
dba900 05-15-2013 04:27 PM
Not sure, but ours is a '77, so it's a contemporary of your Pantera.
sparky24 05-15-2013 04:32 PM
This guy had a 1976 excalibur
http://www.offshoreonly.com/forums/g...ll-switch.html
OCCJoe 05-15-2013 06:02 PM
He is Pepe's age so I'm sure that played a part in the dates . I've heard the story from Pepe and from Coen on how the first 24's dirived and both their stories coinsided with one another . The 24 SB's don't have any pad .
scarab63 05-15-2013 07:01 PM
This debate again:lolhit:
Didn't one of the old timers in the classic section say a magnum or something was the first one to the 24x7 party?
Vintage chrome.....you know the thread I'm talking about, you started it! Not to say what's on this website is gospel....most of us know that's faaarrr from the truth ay this point. But dude makin the statement seemed pretty confident in what he was saying. I think it was tx2 or brownie???? I'll find it when I've got time.:hijack:pbm
tomas_wallin 05-16-2013 12:59 AM
Back to topic guys!:lolhit:
paul buckner 05-16-2013 02:40 AM
OK TRIM TAB PLACEMENT:party-smiley-004:
Boatally Insane 05-20-2013 10:48 AM
Got the trim tabs mounted.... :)
http://i130.photobucket.com/albums/p...ps1e2f8658.jpg
http://i130.photobucket.com/albums/p...psc833d2fa.jpg
http://i130.photobucket.com/albums/p...ps0c537722.jpg
OCCJoe 05-20-2013 07:24 PM
1 Attachment(s)
[ATTACH=CONFIG]501106[/ATTACH] .............. Mirror image of what I had that scrubbed all my speed
vintage chromoly 05-21-2013 09:37 AM
Are they 280's?
OCCJoe 05-21-2013 01:34 PM
No ! Their home made 80's
vintage chromoly 05-21-2013 08:21 PM
Not yours. The ones on the excaliber.
Boatally Insane 05-21-2013 08:40 PM
Yes the are...
Luckily I came across a set of the older "square" ones so they can easily be added on to in the future if necessary :cool-smiley-011:
