Finally started working on my 24. >
Old 06-29-2014 | 08:02 PM
  #111
I lost my new battery switch, bought it December last year when I was collecting parts and now I can't find the damn thing so my wiring is on hold till I get that figured out. I did however get the engine harness started, just need to get nuts for the starter and lengthen the oil pressure sender wire. All brackets and the ignition/alt. are tidy.
Nmbr1GMfan is offline
Old 06-29-2014 | 08:06 PM
  #112
Got the bottom of the trim pump bracket angled (can't tell by the pic) and fit for this spot, not 100% sure this is where it's going but good as any I guess.
Old 06-29-2014 | 08:18 PM
  #113
And a little parting shot. Still have a ton to do but knocking it down little by little. I Ordered my rub rail Friday I hope it works out, 1 1/4 stainless hollow back. I know its taller than average but for this particular boat I think it will work fine and I like the old school stainless look. Ordering carb linkage plate tomorrow and gotta figure out what I'm doing for batteries.
Old 06-29-2014 | 08:37 PM
  #114
For the batteries, I laminated 2 pieces of 3/4 together with a big ear on the top piece. The ear rests on the aft bulk head for support. I used alum. engine mount angles on each end to mount it to the stringers. Holds 2 large batteries easily.
[ATTACH=CONFIG]525405[/ATTACH]
phragle is offline
Old 06-29-2014 | 08:54 PM
  #115
Thanks, Guess I should have been more specific. I have boxes, I don't however have batteries. Do you have a link to pics of your boat?
Old 06-29-2014 | 09:01 PM
  #116
http://www.offshoreonly.com/forums/g...tml?highlight=
phragle is offline
Old 06-30-2014 | 11:06 PM
  #117
Got some wire today! Cleaned up some workspace after work from the weekend thrash, then it was on to some wiring. I wire at a snails pace but we are moving forward.
Old 07-01-2014 | 06:14 PM
  #118
Hey , the boat looks great. We need more high perf boats in this area ,Your project has inspired me to get started on mine (28 magnum ex raceboat). I restore parasail boats here in Bradenton and own a parasail businss. It will be nice to work on something fast again! I'd like to check it out sometime.Plus I have a ton of misc. parts that might help you. Call or text 941 681 1870 Bill.
PARASAIL941 is offline
Old 07-02-2014 | 12:45 PM
  #119
Nice speaking with you Bill, the magnum sounds great.
Old 07-02-2014 | 03:29 PM
  #120
PS pump is on and hyd lines are on for good. Windscreen has been test fit.
