Finally started working on my 24. >
Old 06-20-2014 | 11:08 AM
  #81
vintage chromoly's Avatar
You are really moving along.
What kind of exhaust are you using?
vintage chromoly is offline
Old 06-20-2014 | 11:44 AM
  #82
Stainless Marine.
Nmbr1GMfan is offline
Old 06-20-2014 | 03:30 PM
  #83
I have high expectations for progress this weekend. Got all my cooling pieces, fuel pieces and my pilot bushing this week. I'll update as I can, powder coating brackets starts in the AM. Here is a look at some fuel pieces mocked on the bench.
Old 06-20-2014 | 08:04 PM
  #84
He really is moving along! I wish I was this far along.
Nice work, Nmbr1!
AnurajShah is offline
Old 06-21-2014 | 08:04 PM
  #85
Nice work, Nmbr1!
I have been working on this thing near every day, during the week in the evenings even if it's for an hour or two and weekends. I have until July 4th weekend then I have to spend 2 weeks getting ready to go to TN. for 2 weeks. Thanks for the encouragement.
Old 06-21-2014 | 09:11 PM
  #86
Well I fell slightly short of my goal today because I completely forgot about having to pump the fuel out of the tank as a precaution, I didn't want to use the new fuel system because I'm either anal or an idiot... not sure which. First I started powdercoating my backing plates. As they were cooking I re-installed the old fuel fitting in the tank along with the filter and pump and some extra hose, got about 45gal out. Removed the old stuff (again) and installed the new tank fitting along with the new filter and pump mounted inboard the stringer. Next was the strainer, it went quick but I couldn't find a wrench big enough for the plugs (1-1/2) so I mounted it and will finish it off in the morning after I get a wrench. Since I couldn't finish the strainer I threw the bilge vents on and stuck one of my trim pieces on that go around the top perimeter of the bilge. I'll see what I can get done tomorrow.
Old 06-22-2014 | 01:01 PM
  #87
Moving along nicely, fittings in the strainer and hoses on, cleaned out some threaded holes while I can still get to them and ran the bilge pump wires for easy access later. Going to throw the flywheel and pilot in, trans back on and in it goes. I'll check in tonight.
Old 06-22-2014 | 06:23 PM
  #88
Looking good but how close is your strainer going to be to the front of the motor?
OCCJoe is offline
Old 06-22-2014 | 06:48 PM
  #89
CLOSE! Ha Ha. I already had the engine in for mockup so I could mount everything inboard the stringers. I get in the bilge frequently to clean and I know albeit close on the inside (of stringer) it would make it impossible to get in the bilge and clean around and under the engine had I mounted that stuff outboard stringer.
Old 06-22-2014 | 07:06 PM
  #90
Ing's Avatar
Ing
Veteran: Marine Corp
Default Water Strainer
This is where Pantera mounted the sea strainer in my 24. Awesome work. Keep the pics rolling!
Ing is offline
