Red Roar 1978 24SE restoration starts
#61
Boat is in Devon - I am in Bristol
When I brought my Pantera (in the US in Knoxville) I was initially looking at old 28ft Cigarettes but discovered Pantera through an ad for late 70's 24 SE. It was a Volvo setup. I think it was sold from the Poole area and was £15500 back in the day.
Then I went to the factory and was sold.
and I am one of those idiots who didn't winterise too well but no Im rebuilding not selling a siezed 454.....
#65
Stripped really good condition - tried to hone out one bit of corrosion but now need to rebore 20 would do but probably go to 30 as more choice. Either use Real Steel (I used to work as a Marine Fitter in the 1970's) which a mate in Bordon uses, hes done quite a few 454.
Blocks outside under tarp, crank pistons in the bedroom - all bagged and tagged
In the boat it is some weight with a Bravo 1 and a B&M charger on top but the boats 5 ton all up and looks great and sounds awesome particularly when the blower gives out a little whistle. Not had a problem feather throttle when you come of the plane and its fine.
#66
[QUOTE=Nicolasticity;4256949 Either use Real Steel (I used to work as a Marine Fitter in the 1970's) which a mate in Bordon uses, hes done quite a few 454.
.[/QUOTE]
you say either but who else apart from real steel?.
boat sounds nice and not putting me off a 454 now. not sure i would do much else. just want something reliable as it is going to go to spain so a long way from home.
something that would fit easily to a 280 and sit within its range without screaming the nuts off it 24/7 as it is then bound to let fly
any suggestions
on a mission
.[/QUOTE]
any suggestions
on a mission
#67
Sounds like a nice package apart from the weight , did you buy the motor from larby on boat mad Nick .
