Originally Posted by LakeShakeFever
(Post 4322754)
The swim platform is sick. It is built into several mounting points on the transom. The boat spent most of its life doing the Catalina ski race. I have the pole that mounts in the middle for pulling a skier. But now that the boat will be used for pleasure, it's time to make a stripper pole for the hole.
http://i296.photobucket.com/albums/m...psaeceroxb.jpg http://i296.photobucket.com/albums/m...psre4ltozt.jpg http://i296.photobucket.com/albums/m...pspoqpc7cm.jpg http://i296.photobucket.com/albums/m...psuxdylhxu.jpg |
Originally Posted by OCCJoe
(Post 4322850)
.. 800HP in a non stepped 28 Pantera is going to run 85MPH . It takes 1000HP to hit the 100 mark in the Pantera . THE ONLY BRAVO BASSED DRIVE's THAT WILL HOLD that weight boat and power is the SCX or a Xpower . After 4 years and probably about 20K I've recorded on video and 3gps's 104 mph still only running 800HP N/A . But just to let you know my SB is only 7' beam and it is stepped .
In the end you throw enough power at any boat and you can make it fast , My reality check came when OuterLimits 29' hit 100mph with a 525 and 125mph with 850hp . That was the moment when I realized my hull really isn't that fast . |
I did not buy this boat to be the fastest in the water. I bought this boat because I have wanted a Pantera since I started boating. I like to be different and own a boat that you rarely see on the water. I would say I drive conservative and will do my best to make the drive last. What would you say the max power I can put in this boat to make a reliable package. It has a built XR with 2 hours on it.
Sorry I was just responding to this
(Post 4322676)
Do you think the claim of well over 110mph is possible. If so, could I own the fastest Pantera to date?
I think I'll always want and love Pantera's also but unfortunately they haven't made and probably never will the one that perfect for me .. |
OCC, what ever happened to your 24?
Still setting in the fiberglass building. After were done building the new top deck mold off of it I'm going to set the mark so high for the fastest 24 Pantera ever then I'm going to put stock power back in it and probably give it to my son.
| All times are GMT -5. The time now is 02:28 PM. |
