Pantera 28 performance ??? >
Old 12-18-2018 | 01:19 PM
Originally Posted by bigboat28
The notch allows the drive to be mounted higher which supposedly equals more MPH.
I’m still spacing my stock height bravo down further to prevent blow out. Now that it’s out of the water for the season I’ll be able to get some good measurements.
CooperS7777 is offline
Old 12-18-2018 | 01:24 PM
Any pics of your boat?
Old 12-18-2018 | 03:18 PM
bigboat28's Avatar
Nice looking boat. Looks really warm in your pics. Lol
bigboat28 is offline
Old 12-18-2018 | 05:02 PM
Originally Posted by CooperS7777
Stock 500?
My 28 with carbed 598 has only seen 74 so far. Motor is heading to Saris this winter for top end, new cam and dyno, but Im thinking she's around 700hp. Its also a notched transom so I'm sure its down a couple MPH from a full hull boat.
Stock 500 EFI rebuilt (509ci).
[img]blob:https://www.offshoreonly.com/7588feaf-65a3-49a6-aacf-2f09e692d347[/img]
MMatt28 is offline
Old 12-19-2018 | 02:52 PM
Originally Posted by paul buckner
Thanks for that information Mickey I thought it would be somewhere around that amount , are you single or twin motor .
single engine, speedmaster boat.
mickeymcclgn is offline
Old 12-19-2018 | 02:54 PM
Originally Posted by Craney
Do you have twins or is it a single? Also do you fill the 40 gallons?
single speedmaster boat and if it’s rough I absolutely fill it to the brim. If it’s a 2/3 I’ll put about 1/2 in it (very non scientific measuring system, takes about 60 seconds to fill at 25lbs of water pressure so leave it open for 30 seconds close valve and go) then I have a switch to dump it.
