Tell me about the 28 Pantera... >
Old 04-17-2003 | 06:30 PM
  #51
rtaylor's Avatar
the upgraded drives are for the total weight of the boat, not the engines, right?
rtaylor is offline
Old 04-17-2003 | 08:09 PM
  #52
Pantera24's Avatar
Rtaylor,
The reason I would recommend to go with Bravo's is that it is a stronger drive and will allow you to add more horsepower without having to worry about drive issues in the future.
Pantera24 is offline
Old 04-18-2003 | 12:23 PM
  #53
rtaylor's Avatar
Pantera24,
I'm sorry, I probably didnt ask the question too clearly. I thought that the drive you should choose is not only a function of the horsepower used but also the total weight of what is being pushed. So regardless of the horsepower, shouldnt you beef up the bravo?
rtaylor is offline
Old 04-18-2003 | 02:14 PM
  #54
Caincando1's Avatar
rtaylor,
XR's would be overkill behind a small block. Even if you where running a bigger boat you wouldn't need bigger drives becasue there simply isn't enough HP there to break them no matter what the weight. If your pushing the HP limit of your drive then weight can factor in.
Caincando1 is offline
Old 04-18-2003 | 02:46 PM
  #55
rtaylor's Avatar
caincando1,
thanks.
rtaylor is offline
Old 04-18-2003 | 03:11 PM
  #56
Registered User
TIM THE BOAT LOOKS GREAT,I HAD THE PLEASURE TO GO OUT WITH JO ONCE ON IT, AND THE BOAT HANDLES GREAT IN ANY CONDITION.GOODLUCK TO YOU,IF I SEE YOU ON THE WATER IN THE SBI RACES I WILL APPROACH YOU,NOT IN MY PANTERA, MOTOR AND INTERIOR NOT READY YET,BUT I`LL BE IN A 26 TALON CAT ALL WHITE SO IF YOU SEE ME GET CLOSE TO YOU DONT BE SURPRISED.
ANGEL I WAS THERE TO SEE YOUR BOAT THURSDAY AND IT LOOKS GREAT,FROM WHAT IT WAS TO NOW BIGGGG IMPROVEMENT.GOOD LUCK TO YOU,AND BE SAFE.
ALBERT
MIAMIBOYZ is offline
Old 05-01-2003 | 08:25 PM
  #57
Von Bongo's Avatar
Footwells
Von Bongo is offline
Old 05-01-2003 | 08:26 PM
  #58
Von Bongo's Avatar
sink
Old 05-01-2003 | 08:27 PM
  #59
Von Bongo's Avatar
potty
Old 05-01-2003 | 08:28 PM
  #60
Von Bongo's Avatar
cooler
