28 Pantera Windscreen?
Has anyone done or seen a windscreen for a 28?
I borrowed a pair of "Wind Aways", but the fairing is too fat for them to clamp to. I've seen where a grap handle is mounted and then a deflector is then mounted to that. I'd like a full deflector going all the way around. A powder coated aluminum one would be way cool or some clear lexan. With a curved lip at the top.:) Even if you had one....would it work? You sit up pretty high. Thanks Bruce |
Good question. Since Pantera is on the list for my next boat, I've been wondering the same thing. Maybe there's a way to fashion some clear 1/4" plexi and mount it with some type of thumbscrew so it is removable? I have WindAway's on my current boat and they make it so much more enjoyable, too bad they don't work on the Pantera.
I wonder if someone local can custom make one. I wanted to have a new bow hatch made. I checked around Rochester, trying to find someone that bent lexan. No one did. Maybe someone in the cities?
Jo and I talked about adding a lexan lip to the boat when mine was built and at the last minute I decided aginst it. So I know Jo has the ability to get it done. Much like what you see on the Baja's
Is this what your looking for?
http://www.offshoreonly.com/forums/s...944#post568944 I found it next door in the Sunsation forum. It looks like it would be perfect. |
What made you decide against it Von Bongo? The Outlaw style one is the one that I think of too.
I figured JO could get it done, I was hoping to see other examples, and if you did one, would it be effective? I have a piece of plexi that I will mock up to test. My wife puts her feet up on the fairing while underway and says it helps move the air off her. |
I saw that one Brian. It's getting there. Need something with less fixturing.
| All times are GMT -5. The time now is 09:43 PM. |
