Sportdeck Water Tank
Originally Posted by XPRESS 33PP
I found it in a thread he started a week or so ago. I'll go back and try to find it again and let you know.
....I gave up looking. Sharky has ALOT of pictures and videos on his site
So just to follow up on the water tank....what happens if you turn the switch on and forget about it? Do you have to worry about burning up the pump? Is there any way to tell if it is on or not? Does the hose just start spraying, or is there a button on the hose also that turns it on and off? I found the main swith under the armrest today during my cleaning marathon.
Jromy, the transom shower has a button on the back that turns the spray on. Mine jambs, I take off the front of the nozzle and push it with my finger to close. I don't know if it burns up the pump to leave it on. I don't think it does but I've never tried it. You can hear the pump running if you're inside the cabin and listen carefully, it is pretty quiet,.
Mike
Mike
Xpress33, not too bad, a couple of hours work. The wood/glass is pretty thick, maybe 3/4", at the nose. As always, the right tool for the right job.
Mike
Mike
