-   Powerplay (https://www.offshoreonly.com/forums/powerplay-52/)
-   -   33 Sportdeck Total Weight with HP500 (https://www.offshoreonly.com/forums/powerplay/130270-33-sportdeck-total-weight-hp500.html)
ActiveFun 05-16-2006 10:36 AM
Whats the total weight for a boat lift requirment??
cowisl 05-16-2006 11:59 AM
Re: 33 Sportdeck Total Weight with HP500
I would get a 10,000
ActiveFun 05-16-2006 01:09 PM
Im not sure if thats enough. I think my trailer is rated for 12,000 lbs
PPlay33 05-16-2006 04:52 PM
I have a 12,000lb for a safety margin. if you are full of fuel, gear,any people on the boat,etc. The price is almost the same.
Semper Fi 05-16-2006 11:27 PM
Better to be safe than sorry :drink:
ActiveFun 05-17-2006 08:54 AM
There wont be any people in the boat. Its for when the boat is not being used and stored on a lift behind a house.
Ed 05-17-2006 06:27 PM
We always bought 10,000 lb. capacity tandem Myco or South Florida Trailer, trailers for any of the 33's...whether is was an inboard or an outboard model. 10,000 is fine for a lift as well. There is a good safety factor of weight capacity designed into all lifts. The only reason you would buy larger, would be if you were planning for a larger boat in the future, which you might want to consider. The PP brochure weights were decieving, as they represented completely bare hull & deck "fiberglass only" weights. I believe the brochure stated the 33's weight at 2,950 lbs. There were no light lay-up pleasure boat 33's. The lamination schedule was the same for every 33' SD, from 1990 on up. The race boats were a different story. 1987, 1988 & 1989 production lamination schedules were different as well. Hope this helps. Ed :)
ActiveFun 05-17-2006 06:34 PM
Thanks Ed, that really helps. I dont really know the cost difference but if I can go with a 10,000 lb lift, then there is no reason for 12k. Thanks again.
Ed 05-17-2006 07:23 PM
Glad I could help! :drink:
