33 PP Props
Anyone try a set of Hydromotives compared to labbed Bravos?? The previous owner of my boat has a set. He said the top end was better but getting on plane suffered.
Re: 33 PP Props
I've got 28 pitch hydro's on my 33 and I really have to feather it comming out of the hole or the props will cavitate and i will have to back down and start over. I have not tried any other combo as these were on the boat when i bought it so i have nothing to compare it to.
Re: 33 PP Props
I love my 28 lab finished bravo I's.
Re: 33 PP Props
cowisl, what year is your boat and with what power?
By the way, did you get squared away with the EAO switches? Mike |
Re: 33 PP Props
I have a 1995 28 with 300 promaxes... I know its not a 33, but these props spinning in make the boat scream. THanks for your help with the switches, we finally got them fixed.
Re: 33 PP Props
Active, I've used both. Every boat is different, and every prop is different. The bravo prop is probably a better choice. In stock form they are slow, but labbed they have about the same top end, maybe better if worked for your boat. The bravo has a better cruise speed and is a little more stable at high speeds. I would try any props I could though if he will loan them to you. Good Luck. Don
Re: 33 PP Props
PPlay33...are you spinning in or out? What's your power too?
Re: 33 PP Props
Indy. I am spinning out with 32 labbed bravos and about 700hp per side. I have never tried spinning in on this boat. I am very happy with the ride and handling of the boat at any speed or water condition!
Re: 33 PP Props
Originally Posted by PPlay33
700hp per side.
| All times are GMT -5. The time now is 10:24 AM. |
