Go Back  Offshoreonly.com > Owners Forum > Powerplay
Powerplay Boats >
Powerplay Boats
Powerplay Boats
Old 04-25-2011 | 12:07 PM
  #1961
if theres nothing to move in the boat to correct the cg, and it is way to far back, what is the next best option??? leave it or ad weight in the bow???
302Sport is offline
Old 04-25-2011 | 12:16 PM
  #1962
Steve 1's Avatar
Bow tank,but you pay the price as every gram takes power to move it.
Steve 1 is offline
Old 04-25-2011 | 04:44 PM
  #1963
Good thing about a tank is you can fill it when you need it and empty it when you dont, where just adding weight will hurt a bunch when you don't need it. the farther forward you put it the less amount you need.
fastdonzi is offline
Old 04-25-2011 | 05:33 PM
  #1964
northernoffshore's Avatar
Originally Posted by baha boat freak
hey can you please tell me what speeds this boat was doing max. and wat would a 25 sports deck do with twin 2.5 260/280's or twin 300xs promax wat will yhe speeds be thanks. i have one and want to rigg it to reach great speeds to race in and just to be a fun beach day boat, and whats the fastes this hull can go? and with >? thanks!
80+ with 225 promax and 28 choppers.. I like the lighter weight of the 2.5's on the boat
northernoffshore is offline
Old 05-04-2011 | 08:41 PM
  #1965
ludo73 is offline
Old 05-05-2011 | 10:44 AM
  #1966
...and a sizable bow tank adds a big polar moment of inertia which can have a negative impact on pitch stability. Shifting the large masses (engines) to achieve the desired Lcg position (with a small bow tank to fine tune) works much better from a dynamic stability perspective.
ND1
nautdesign1 is offline
Old 05-05-2011 | 12:27 PM
  #1967
how much does shifting the motors effect a 33ft v bottom????? for instance shifting motors 1 inch equals how many inches of COG change???????
302Sport is offline
Old 05-05-2011 | 08:23 PM
  #1968
(weight x distance)/deadweight....i think. havent done any stability in a few months
sixmassive is offline
Old 05-05-2011 | 10:19 PM
  #1969
What's that formula giving you???
302Sport is offline
Old 05-06-2011 | 12:21 AM
  #1970
the moment. shows how far it moves. if you also must raise the motor a little, that messes with VGC ( vertical center of gravity). use the same formula
