-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   vac-u-flush toilet (https://www.offshoreonly.com/forums/powerquest/130324-vac-u-flush-toilet.html)
enticer 05-19-2006 06:06 AM
Re: vac-u-flush toilet
And is the Vac system on the starboard side under the throttles?
Macklin 05-19-2006 11:41 AM
I have the same system that BillR described in the old thread you posted a link to. Probably the same as yours.
Vyper340 05-26-2006 06:03 AM
Vac and holding tank located under the throttles. Water is supplied by the fresh water tank/pump so be careful when using bleach in your water tank.
bigvander 06-26-2013 06:31 AM
I have a 03 legend that I just bought and I'm trying to figure out the plumbing in the cabin. The small area where the sanipottie goes is currently being used to store a fender but that little compartment smells awful. There is a 2" ribbed hose that leads up to the bow - I'm assuming this is the flush port. There is also garden hose with a female end. Is this a vent hose? How do I get the smell gone? No weekender package, just setup for portapottie. Thanks.
bigvander 06-26-2013 08:08 AM
boatnt 06-26-2013 09:36 AM
yep the small hose is the vent which vents out in the front kind of where the docking lights would be..
you sure you dont have any old water sitting in any of the storage compartments?without a porta pottie there I dont know why it would smell
