Go Back  Offshoreonly.com > Owners Forum > Powerquest
Power Quest is getting some love >
Old 12-08-2006 | 08:33 AM
pkspx's Avatar
Default Re: Power Quest is getting some love
Originally Posted by Gary C
I was told that the regular bottom PQ's were set with a low X and the 280 with the step is a higher X That is why the 4 blade on the 280's. That is also the reason the 260 and 270's work with 3 blade props. It is basicly trial and error. Most Hi x demension boats are harder to get up on plane, but once on plane are faster on the top end. There is always a trade-off.
pkspx, if you aren't already you will probably need to go to a 4 blade prop with that shorty.
have the Hydromotive 4blade 23p but looking to go 5blade with the IMCO shorty. From the comments on this thread, makes me wonder if I am wasting my money. I was told Power Quest has the drive too deep because it is a pleasure boat making it easy for anyone to get off plane. Am I actually going to notice any difference in speed or stability? What else can I expect?
pkspx is offline
Old 12-08-2006 | 08:35 AM
pkspx's Avatar
Originally Posted by Fast Forward
Just wondering how one determines whether your X dimension is set high or low? Or if it's simply a trial and error situation?
distance from crank to prop shaft
pkspx is offline
Old 12-08-2006 | 08:43 AM
Knot 4 Me's Avatar
You will definitely have to go to a 4-blade. Depending on your HP and gearing, 5-blade may be too much to pull. Plus you may end up roaching your drive if you get that 5-blade hooked up. You can go too high on X dimension and lose speed. Worst case is you go back to the stock lower or use spacers at 1/2" increments to find the sweet spot. Takes time, testing, and $$$$. Good luck and let us know how it works out!
Knot 4 Me is offline
Old 12-08-2006 | 08:51 AM
pkspx's Avatar
If I posted my drive x, would you guys be able to give a better guess? Drive is 1.5:1 bravo 1
pkspx is offline
Old 12-09-2006 | 08:25 AM
Yea, the previous owner spent a considerable amount of time "tweaking" the boat, a couple other guys (Macklin and BillR) might chime in and shed some light on what was done to my boat. It also has Gil exhaust and a K&N filter but the increases came from the labbed prop and the 1" spacer. He felt like the prop was getting too much air.
HotBoat did an article on the 5 blades and they broke the prop shaft because of not enough slip.
Pete280 is offline
Old 12-09-2006 | 09:17 AM
Mentalpause's Avatar
Probably because the X-dimension was too high.
Might be good to ask a couple folks where the center hub of their prop is in comparison to the bottom of the boat. My guess is it is an inch or 2 below the bottom.
Mentalpause is offline
pkspx
Powerquest
9
03-05-2008 10:45 AM
pkspx
Powerquest
3
01-12-2007 07:52 PM
pkspx
Powerquest
3
01-08-2007 12:00 AM
pkspx
Powerquest
0
06-01-2006 08:04 AM
POWERQUEST
11
06-18-2004 12:35 PM
