-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Gas Tank Sending Unit (https://www.offshoreonly.com/forums/powerquest/151693-gas-tank-sending-unit.html)
Fast Forward 02-17-2007 05:26 PM
I changed out my gauges last summer and noted my fuel gauge is really off now. Years ago when I worked a marina we had to adjust these from time to time. The old units were either an arm style with a float and you simply bent the arm to make your adjustment or a screw style with a float. I've not had a chance to pull the sender and was just wondering if anyone else had to make any adjustments and what style sender PQ used?
Mentalpause 02-20-2007 09:18 PM
I had the arm type on my 270. Seems odd though that changing out the gauge would require modifying the sender. I've never had to change out the guage though, just the sender. When you take it out, it is best to get a new gasket when you put it back in versus putting the old one back in. I tried replacing mine with the old gasket and a few days later ordered the new gasket too.
jeff1000man 02-20-2007 09:52 PM
Does anyone know about the digital flow meters that hook up in line from the tank to the engines. Supposed to be super accurate and take the sender and fuel guage out of play?
Mentalpause 02-21-2007 07:09 AM
But don't they just measure instant flow and total usage over specified period? That is how my Merc RaceView works. But it would not take the place of the fuel gauge.
jeff1000man 02-21-2007 07:15 AM
If you knew how much fuel was in the tank - Full of gas - and how much you used - over time - wouldn't you know how much was left, or do they not give cummulative figures. Example, if you turn off the boat and then re start it.
I can't get to my sender, so I am looking for an alternative to tearing out the floor.
What was yours called again?
Dave Kline 02-21-2007 04:07 PM
Jeff,
Check out floscan.com for a flow meter.
Mentalpause 02-21-2007 08:00 PM
As long as you always filled up your tank the flow would work. Mine does keep accumulation until reset, so it does not matter if you turn off the engine. But if you fill up so many gallons here and there eventually it would be off.
Mine came as part of the Merc package with the PCM03 computer.
Fast Forward 02-21-2007 08:53 PM
John, Thanks for the heads up on the gasket. I hadn't thought about that. I'll pick up a new one before I pull the sender.
Mentalpause 02-21-2007 08:57 PM
Good luck with the change out!:D
