Avenger cabin door problem
I know this topic has popped up a few times. On my cabin door the lower slider block pulled out of the door I know Scott had the same and many more issues with this piece of $--t design. I need how involved it is to remove the door so I can put longer screws in the block.
Rick,did you get a 38??
A freind logged in under my ID....
I had a problem where in rough water with the cabin door closed .....the movement (real quick) ripped the locking mechanism out of the lexan plastic. Took it back to the factory and they repaired it and then stuck a sticker on the door "Do not run boat with the cabin door closed"
They mentioned that it was a pain to do I tried to upload a pic ot the door....but it does not want to go. |
cahin door
It is a pain in the a$$, had to remove black rubber pad on the starboard footrest and cut an access hole to get to the rear of the door and do the fix. The only good thing is I had custom billet aluminum step plates made to cover the access hole.
1 Attachment(s)
I emailed the God's and asked why I couldn't upload a picture.they said the sight was down....I really didn't see that. I will try to upload the pic again
How did they fix the problem with the latch? Does your door have slider blocks or rollers?.
Slider blocks...which I have already had to reinstall them. The factory did the door and said it was a *****!
I have a nice access panel cut in the head and installed one of these so I could work on the piece of ****!
http://www.tempress.com/catalog/prod...ducts_id=44335 I have another company in my area trying to make a electric slide door to replace the junk track system. I will update when they come up with something. I have to repair the rear track once a month nothing but F***ing junk!!!!!!!!!!! Ya Think I'm pissed!:mad: |
Door
My track seemed to be pretty solid, the tiny self tapping screws that held the blocks to the door were my problem. How did you reattach the track.
| All times are GMT -5. The time now is 01:06 PM. |
