prop selection
Need some help on prop selection;-)
Upgrading 1996 257 PQ hp500 to 675hp, anybody with the same specs played around with 3 / 4 blade / pitch what was your outcome? |
I'm running a B-1(4 blade)28 pitch on a PQ280 with around 650 hp. Bob
Originally Posted by Bob280Silencer
(Post 3034069)
Top speed / RPM and your elevation, I’m sitting at 4500ft |
Top speed 78-80 gps
Elevation...that's funny ZERO (New Orleans) RPM 5400-5500,pretty busy at that speed in a 280,can't always check. 3600-3700 is around 53-54 mph My rev limit is set at 5800,I probably could use a smaller prop,let rev higher and get more mph but I'm not really into top speed all that much. I enjoy the "mid range pull" and the cruise speed.Hope this helps. Bob |
(Post 3034537)
Top speed 78-80 gps
(Post 3034537)
Top speed 78-80 gps
I had a 1" spacer when I bought the PQ.The lean to port was extreme as it started to lean at 45mph.I removed the spacer and that corrected the problem.However it will still lean at 65+ but not all the time. It depends on the wind and water conditions.
Well... I think my slip problem is because prop is to high. I would hate to create more lean though. Another possibility is a 5 blade but I would bet that would create more lean. Do you have the spacer you would like to sell?
Why did you remove the spacer? |
sure,I'll sell it. I removed it because the boat didn't need it.It comes out the hole like a 21 footer,no blow out,runs flat with less lean to port. The first owner thought it needed bow lift and thought the spacer would help. I like it without . Bob
(Post 3035455)
| All times are GMT -5. The time now is 03:23 PM. |
