Go Back  Offshoreonly.com > Owners Forum > Powerquest
Needing to drain it. >
Old 08-08-2010 | 06:56 PM
PWRQWST's Avatar
Default Needing to drain it.
Ok who has had to drain fuel from a avenger? I am trying to get mine drained and it seems when pushing the hose down the filler neck I hit something down there, I am guessing a screen but not really sure. Does anyone have any ideas on how I can do this?
PWRQWST is offline
Old 08-08-2010 | 09:18 PM
remove the fuel sender and stick the hose in the tank
boatnt is offline
Old 08-09-2010 | 06:28 AM
Mentalpause's Avatar
Ditto, should be an access through a floor panel.
Mentalpause is offline
Old 10-07-2010 | 02:32 PM
PWRQWST's Avatar
Well there is one problem, when "I remove the cover all I have is two elbows showing. One is the filler neck and the other is the vent hose. I wish it was a simple as pull the sender, but just my luck its not. Any other ideas?
PWRQWST is offline
Old 10-07-2010 | 08:20 PM
take it out one last time!
Pete280 is offline
Old 10-07-2010 | 09:38 PM
PWRQWST's Avatar
I wish it was the easy, but the starbord motor is out of it right now.
PWRQWST is offline
Old 10-08-2010 | 01:34 PM
spazboz's Avatar
If the motor is out, couldn't you get most of the fuel out by hooking up an electric fuel pump to that engines fuel line?
spazboz is offline
Old 10-08-2010 | 01:57 PM
you should have one more access panel under the rear seat for the fuel level sender
boatnt is offline
Old 10-08-2010 | 02:44 PM
PWRQWST's Avatar
hmmm I think you are correct, but within the first month of owning this I had a big sub box built under the rear seat. I will have to take that apart to look, thanks
PWRQWST is offline
Old 10-08-2010 | 02:45 PM
PWRQWST's Avatar
I was thinking that myself and wasa going to give that a try this weekend, thanks
PWRQWST is offline
