-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Max power in an Enticer? (https://www.offshoreonly.com/forums/powerquest/239706-max-power-enticer.html)
AngerMgmt 09-25-2010 10:48 AM
Any ideas what an Enticer hull can handle as far as power/speed? Currently has carbed 454 mags (330hp) with B1's/Imco -2's, Bravo 1 26p 4blades. Runs 67-70 depending on load in boat.........
Original motors with 430 hrs and no problems.....just want a little more speed. I'm thinking about mildly built carbed 502's (for reliablility). Maybe 425-450hp. Can the hull handle that power without being too squirrely? Will that likely get me to 75-80? Would I have to change to hydraulic steering?
Would appreciate any comments............Mark
AJ POWERPLAY 09-25-2010 02:32 PM
The boat could handle 500efi's with xz drives or beefed up bravo 1's... also another option is 540's a guy on torch lake with an older enticer has one with 540 bulldogs in it. If you want to be around 80 in an enticer id recommend getting k-planes to replace your stock trim tabs and keep running 4-blade props to avoid chine walk at 70 and beyond. I'm running 7.4mpi 310hp's with 25p mirage plus's labbed to 24p by BBlades... got 69.57 on gps last time I ran it with 2 people and a little under half tank. Built 502's will be sweet in that boat let us know what happens
endeavor1 09-25-2010 05:51 PM
external steering is a must IMO
boatnt 09-25-2010 06:43 PM
+1
Jplanes 09-30-2010 08:28 PM
Mark, it's been a while buddy!
My old bucket has factory 502s with 23p 3 blades (starboard has about 80sh hours and the port about 300+) Best I've seen is 71 GPS. I've got the big Kafer K planes too, just would like a little more mph! Love to hear what you do and what you get out it!!
Jake
AJ POWERPLAY 10-01-2010 01:27 PM
Jake
You need labbed 25 mirage plus's or labbed 26 bravos and you would see an improvement... you're under propped with 502's. I have the 310hp 7.4mpi's with 25p mirage plus's labbed to 24's and the best I've seen is 69.57 on gps
Jplanes 10-02-2010 09:05 PM
Thanks Aj, and not that I don't believe you, just want to hear what others have to say about this set up. Thought I read in another thread that this was the right setup for the 290 502s? Sorry to hijack, however it would be nice to get some extra MPH!
AJ POWERPLAY 10-04-2010 10:00 AM
My boat season is done, if you'd like to try my props you're more than welcome to
Jplanes 10-05-2010 07:10 PM
AJ, if we lived closer I'd definitely take you up on your very generous offer, yet I hate taking responsibility for other peoples stuff! I definitely want to prop up, yet I gotta keep priorities in check. Fix starboard drive boot, fix 2 in scrape in my gel from my hydro lift, and would like to do what you did (touch up and change the paint and upholstery) . Not to mention finish up my other toy and love of my life this winter. Thanks again, and sorry for the 2nd Hy-jack:drink:.
