-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   GPS Recall / reset switch (https://www.offshoreonly.com/forums/powerquest/24301-gps-recall-reset-switch.html)
Scott 05-13-2002 09:53 PM
I did not want to use the switch from Gaffrig I did not like the look of the switch or the fact that it would not match anything. I bought a new rocker switch to replace the windshield wiper switch (like I need that):rolleyes: used a label maker for the lettering. I know that sounds crude but it came out o.k.:)
Scott 05-13-2002 09:56 PM
1 Attachment(s)
Try it again:D
Scott 05-13-2002 10:03 PM
1 Attachment(s)
Ray,
This is what I came up with I'm still not sure if I like it but better than what I had. It looks better from up top than a bilge close up but you get the idea.
Raypanic 05-19-2002 02:07 PM
Looks good Scott, I wish I could reach my cables in order to do the same, I looked at it quite a bit and It is just too hard to get at. I got the polished aluminum Battery holders The look nice, I figured I would get polished so If I want to re-sell them later it would be eaiser than Teal. Also I have polished stainless steel exhaust pipes so it will match them too.
How about some more pictures? I know you must be getting the engines close to done.
Scott 05-21-2002 08:18 AM
My blocks are not ready:mad: They better be done today I plan on hauling it to Sandusky tomorrow to install the new motor mounts and allignment. I want to do this with a empty block so we have room to move around in the bilge. Then I will bring it back home and finish the motors. I should be finished in the next couple of weeks :D
I don't have any new pictures all that I have been doing is re-routing cables and wires plus adding cushion clamps in place of wire ties. I cant believe some of the short cuts taken in the original install. I don't think a wire tied fuel line is exceptable:eek: The last many hours have been spent with a buffer Finesse it II and wax. That's a lot of boat even with a buffer:rolleyes:
