-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   34 vyper filler cushion (https://www.offshoreonly.com/forums/powerquest/249670-34-vyper-filler-cushion.html)
mcr vyper 03-19-2011 03:11 PM
I am looking for a white vinyl filler cushion for a 2002 34 vyper.Does anybody know of one for sale? Or if anyone knows were i can get one? Also If someone can post a picture of the filler cushion, intalled between the u seating area and maybe the bottom of it and how it mounts, so if i need to make one myself. Thanks.
AJ POWERPLAY 03-19-2011 05:07 PM
I have filler cushions in my 290... they are mounted with dowell rods across the opening and when not in all u can see is the mounts. They are filler cushions cut length wise so its easier to remove, I can take pics soon, would be easy to duplicate
Need4SpeedGTCS 03-19-2011 06:56 PM
I would like to see that too. Table and post (& mount) easy enough to build but how does the table/cushion piece fit in level with the seating. Where does the cushion store? Table has a spot under the v-berth...does the cushion cram in under that?
My 270 is the same as the 290, rods run across the seats then the seat bottoms and backs all lift and move in.
verbi69 03-19-2011 08:05 PM
2 Attachment(s)
Here's a pic....
mcr vyper 03-21-2011 07:50 AM
Do you have pictures were and how the rods mount in place between the u seating? If you can post them ,that would be great. I want to make sure I know how to do this, so I can make a table & filler cushion.
Thank you.
Need4SpeedGTCS 03-22-2011 11:04 AM
Thank you.
All the pic's I've seen on the net it looks like the 340/380's just use a shorter table post. Look of the hardware and lots of surfing I think the brand is Taco Metals Marine Products (yes Taco). West Marine sells their stuff but my question is wihich model, the post is it 60mm or 76mm diameter? base diameter?
Verbi, got a measuring tape handy? also, how tall is each tube?
Piersupply.com has some good prices and better choices/descriptions.
verbi69 03-22-2011 11:21 AM
My cushion sits on the table which uses the shorter table post.
Can't tell you what size/ length until I get the boat home...
Need4SpeedGTCS 03-22-2011 11:29 AM
Verbi, appreciate any all info whenever you can send it.
With my schedule and weather out here I won't see my boat until the end of June...:eek:
verbi69 03-22-2011 01:13 PM
No prob, anytime.
I'm in the same boat as well as far as weather goes......:picard1:
mcr vyper 04-09-2011 10:16 AM
Does anyone have their boat home yet and could you please post pictures of the table and filler cushion for a vyper 34. I need to make one and the pictures would help.
Thanks.
