Go Back  Offshoreonly.com > Owners Forum > Powerquest
Trailer brakes >
Trailer brakes
Trailer brakes
Old 05-08-2011 | 02:19 PM
Default Trailer brakes
I am wondering if anybody else has had trouble with there trailer brakes on there powerquest trailers made by r and d trailers? I just overhauled mine so they would work and I cant back up without them locking up and there is not a lockout seloniod on them and no lever to lock it out manually I am thrown for a loop! Any help would be greatful
clayboy is offline
Old 05-08-2011 | 03:27 PM
disc or drum?
if you have disc brakes than you will need to install a back up solenoid...
if you have drum brakes than you might have them too tight...adjust brakes until they drag and then back up 10 clicks.
boatnt is online now
Old 05-08-2011 | 08:40 PM
Cool
Thanks! I have the drum setup and when I rebuilt the system I just cranked the adjusters down tight and then just backed them off a little till the wheel turned they may still be cranked down to tight I will have to crawl under there and try backing them off 10 clicks.
clayboy is offline
