No the hpcarb came with the Gill manifold.
Nothin better than a fresh set of motors! Lookin very good! Something about that merc blue that gets me going. I cant wait to see it in person!
Re: Rebuild update
Looking for help !!!!! 1990 Powerquest Enticer 29..... On my 4 motor that has spun rod bearings..... any thought... Both motors were blue printed, and balanced... just bad luck or ?????
Re: Rebuild update
What motors are you running?
what RPMs are turning and what weight oil are you using? has it been always the same rods that spun? last time the motor was out did you do anything to the crank? and did you line bore the block? |
Re: Rebuild update
You need to add a ton of info here. Just because it's a PQ it has nothing to do with the engine and may be better off posting in the tech section.
One thought that I immediately had. Did you hook up the oil lines backward? |
| All times are GMT -5. The time now is 01:27 PM. |
