P.Q kplanes
Old 09-08-2011 | 09:22 PM
Originally Posted by ajfisher
You need to run 3 blade Labbed props to get speed out them though,
true..Labbed 3 blades will get you the most speed..
boatnt is offline
Old 09-08-2011 | 09:38 PM
who do i send them too?
what should i ask? or just tell them to labbel them?
eriknelson is offline
Old 09-08-2011 | 09:49 PM
call BBlades and ask for Brett
I think its BBlades .com
boatnt is offline
Old 09-08-2011 | 09:51 PM
I installed a set of 19x14 Lencos on my 2000 290 and they helped..
boatnt is offline
Old 09-08-2011 | 10:13 PM
cool thanks - i hope after the new kplanes - spinning the props out, and having the props labbled, maybe i can loose the the chime ?
i don't know if i mentioned , im usually in chop - niagara river, and lake erie
Old 09-08-2011 | 10:18 PM
btw - if you come across any used or good deal on mechanical trim gauges for the drives, and drive showers let me know...
I have spent a ton on this this year! ugh lol im sure you understand!
Old 09-29-2011 | 11:24 AM
Josh LaFountain's Avatar
My 280 chine walks at full speed also. There was a PQ dealer in my home town up untill they went out of business and now thay specialise in Baja. I know the owner of the dealer ship and he told me that its because of the step hull. All the mid sized single step PQs had that issue with chine walking at high speeds with them trimed up. And he also stressed that you should never jerk the throttle back when it starts walking, It will cause the rear of the stern to lift wich boils the water even more with the step hull causing the out drive to loose bite in the water and can cause you to loose controll and possibley spin out. He told me the safest way to bring it out is to slowley bump the trim down and you slowley reduce throttle. Hope this helps.
Josh LaFountain is offline
