Go Back  Offshoreonly.com > Owners Forum > Powerquest
Trim Tabs Not working. >
Old 10-17-2011 | 07:51 AM
Josh LaFountain's Avatar
Thats it. The pump isnt running. Hopefully its one of thoes solenoids. Ill do some testing. Thank you for your help.
Josh LaFountain is offline
Old 10-17-2011 | 07:58 AM
Josh,
The solenoids open the valves for the hydraulic fluid, so it's probably not them that are keeping the pump from running. Check the ground wire on the pump as well as the red and yellow wires at the pump. The red runs the pump forward (tabs down) and the yellow runs the pump in reverse (tabs up). If the ground is good you can try putting 12 v positive right on the yellow wire at the pump. You should hear the motor spin when you do this. If you do not hear it, then the motor has likely failed.
Tom
Bennett Marine
Tabman is offline
Old 10-17-2011 | 11:36 AM
Thanks again. Can I install Kplains on the stock rams? It has twin rams on each tab.
Old 10-17-2011 | 12:07 PM
Josh,
If they are the stock Boat Leveler actuators (rams), they will look like this:
I really don't think they would hold up to the larger, heavier K-Planes.
If you intend to install K-Planes you should use the actuators provided by them.
Tom
Bennett Marine
Tabman is offline
Old 10-17-2011 | 02:57 PM
Default ..
Thay look sorta like that. Here is a pic. 2 rams has to be better than one rt? lol
Old 10-17-2011 | 03:50 PM
k planes have a large bracket that bolts to the transom and need it support so it doesnt push the rams through the transom
Unlimited jd is offline
Old 10-17-2011 | 04:30 PM
Makes since.
Old 10-28-2011 | 06:59 AM
i was also looking for that kind of info.....thanks,tom
pqjack is offline
Old 10-28-2011 | 07:02 AM
mine are also identical....someone knows what brand they are?
pqjack is offline
Old 10-28-2011 | 08:57 AM
I'm quite sure they are 'Boat Leveler'....by Insta-trim.
I still have all my paperwork etc. with my '93 Laser which has the same...http://www.insta-trim.com/hev.html
Need4SpeedGTCS is offline
