Go Back  Offshoreonly.com > Owners Forum > Powerquest
forward bilge pump? >
forward bilge pump?
forward bilge pump?
Old 12-08-2011 | 08:06 PM
Default forward bilge pump?
Guys: Just gathering materials for the improvements to the new boat. Does anyone know if the Avenger has a forward bilge pump? When I turn the switch on, I only hear one running in back. Does the forward bilge area just drain to the rear?
vista268 is offline
Old 12-10-2011 | 10:50 AM
Default Bilge pumps
My Avenger has two pumps one under each motor - one is automatic & one manual with the switch on the dashboard. It does not have a pump up front.
Don OHIO is offline
Old 12-10-2011 | 11:15 AM
My friend 2002 380 also has 2 in the engine compartment.
boatnt is offline
Old 12-10-2011 | 11:43 AM
So, just gravity drain to the back if water ends up going in the cabin step drain. I am going to take a look at adding a forward bilge when we do the air and will report back.
vista268 is offline
Old 12-10-2011 | 01:32 PM
Under the cabin step I think you will find the shower drain pump/holding tank
boatnt is offline
Old 01-03-2012 | 09:13 PM
asb929's Avatar
My silencer with step hull has no front bilge pump only way for any water to flow past step is when getting on plane.
asb929 is offline
