-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   280 Sub placement advice (https://www.offshoreonly.com/forums/powerquest/273079-280-sub-placement-advice.html)
Josh LaFountain 03-26-2012 08:57 AM
I have 2 12" Polks in a sealed box in the engine compartment. It pounds but it viberates the side of the boat so bad it makes the water ripple and sounds kinda bad if ya turn the subs up very far because everything in the boat rattles. But its Crazy loud. ive also got 2 sets of Boston pro componets in the cockpit. And thay SCREAM!
boatrider82 03-26-2012 12:25 PM
Originally Posted by Bob280Silencer (Post 3649123)
My 280 was the factory demo boat and they put the speaker in a box in the engine bay on the port side. Probably a better place to put it but you don't loose any space.
Wouldn't mind seeing a pic of that!!
tmeyer33 03-29-2012 09:44 PM
When I purchsed my boat it had two ten inch bass tubes in the side pockets. I could push them up far enough so that you couldn't see them and they sounded great. Thats on a 290 I don't know how big the side pockets are on the 280, Might be worth checking into easy install...
boatrider82 03-29-2012 09:53 PM
Mite look into seeing how hard a box would be to put in there I like the fact its out of site though
AJ POWERPLAY 03-30-2012 02:04 AM
Once again... Free air subs under the seat, no box needed and they give the proper sound needed for an open cockpit application. Anything else and you're just throwing your money away.
diggin H20 03-30-2012 11:01 AM
The 280 cannot fit free air subs under the seat. It has a fiberglass storage tub with drains that takes up the under seat area. I believe it's the only model like that.
Josh LaFountain 03-30-2012 12:54 PM
Originally Posted by diggin h20 (Post 3652496)
the 280 cannot fit free air subs under the seat. It has a fiberglass storage tub with drains that takes up the under seat area. I believe it's the only model like that.
+1
Josh LaFountain 03-30-2012 12:55 PM
And it makes a great cooler for 100 cold beers.
AJ POWERPLAY 03-30-2012 02:53 PM
You can put them in the sides up by the driver and passenger... Or anywhere really, without the need for a box the mounting options are limitless... Think outside the box, literally lol
boatrider82 03-30-2012 04:39 PM
LOL Im looking at a couple of options when I get them in I will post pics
