-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   380 shift problems bravo xz drive (https://www.offshoreonly.com/forums/powerquest/298529-380-shift-problems-bravo-xz-drive.html)
Questofpower 06-21-2013 06:12 AM
Guys, that 380 we picked up a few weeks ago shifts pretty hard. I am going to pull the back plates off and take a look at the detents. I also want to lube up all the moving parts from the levers back. Any one have a diagram so I make sure I get everything. Also what do you lube the detents with, are they not in the drive lube, I have never pulled a back plate off, but I am sure it is pretty self explanatory once I get it off.
My understanding is shift lever to a cable that runs back to the transome plate few moving parts there, then a rod going to the back back plate with a few moving parts under there, sound about right?
Never mind answed my own questions http://www.offshoreonly.com/forums/p...be-points.html just had to search a different way.
Thanks Boatnt.
boatnt 06-21-2013 08:14 AM
the detent ball/spring assembly is not in lube,,its in a dry cavity...you do have to drain the oil on the outdrives,,then remove the 3 bolts and the rear cap comes off,,,remove the spring assembly and and with your thumb push it in against the spring to break it loose,,, i use the merc green lubricant I think it merc 2-4-C
Questofpower 06-21-2013 05:35 PM
Thanks that was the lube I was guessing just wanted to make sure.
Questofpower 06-27-2013 07:25 PM
Definitely the detent, shifts much easier now. Also took a little slack out of the cable on the engine plate. Not a bad job at all, about an hour start to finish. Just a little scared to open the magic black box up, but not anymore.
Rock Star 06-27-2013 11:36 PM
Not only does it shift into gear great, on the shakedown cruise we played with the drives and who would have thought that this boat likes a lot of trim to reach top speed. Full trim of 9 on the indicators and 5100 rpm reached 76, any less trim slowed the boat.
