Go Back  Offshoreonly.com > Owners Forum > Powerquest
Installing A Transducer in a Vyper >
Old 01-22-2014 | 08:01 PM
Originally Posted by Pwraddr
Hey Tom,
When I had my fridge out there is a plywood shelf that the fridge and air conditioner and bottom of the storage under the sink. By my build photos there would need a hole drilled in it to access underneath.
Can't remember how to post pics or I would.
Rich, post the pics I sent so Tom can see what I mean, maybe he knows something that will help.
Keith, is this one of your build pics? Not sure if there's enough detail but hope it helps...
I get what Tom is saying with the 380...large open access under my fridge. 340/380 difference?
Attached Thumbnails Installing A Transducer in a Vyper-baba66fe32d86235b8cf2ccc3301afab.jpg
Need4SpeedGTCS is offline
Old 01-22-2014 | 08:15 PM
Hey,
Yes that is a pic from my Vyper. What does the fridge sit on in an Avenger? I have another pic of the "floor" that I sent Rich via email and that entire section is cover in plywood. As mentioned, my air, fridge and bottom of storage compartment under sink is one piece of plywood.
Must be different, but still curious what the fridge sits on.
Edit. You can see the factory transducer wire in that pic....when you enlarge a bit.
Pwraddr is offline
Old 01-22-2014 | 09:24 PM
"air, fridge and bottom of storage compartment under sink is one piece of plywood" On my 380 that piece of plywood is already cut open in the 'triangular' area at the stringer. Infact I even have a sump box for the A/C condensation drain in the area up to the bulkhead.
Old 01-22-2014 | 10:37 PM
the fridge sits on the stringers and the back rests on the front step(hull step),you can see the step behind the stringers by the line I drew,,the depth finder is were I drew the arrow,,no plywood,,its right under the fridge,,at least that is how it was on my friends 02 380 and a 2000 340 that I saw with the fridge out of it.
the plywood panels forward of that are the storage compartments under the cusions
boatnt is offline
Old 01-23-2014 | 02:18 PM
rrentsch's Avatar
Registered User
Thanks Guys, I will let you know how it goes when I get into the project when it warms up. I will take pics and post them
Thanks Again, Rich
rrentsch is offline
Old 01-23-2014 | 07:22 PM
Gotcha. Not how mine is but now I understand.
Pwraddr is offline
Old 01-23-2014 | 07:29 PM
[ATTACH=CONFIG]517056[/ATTACH]
This is where my fridge sits....immediate left is the air conditioning.
Attached Thumbnails Installing A Transducer in a Vyper-37179627d21dac47c55fbd2bcef79323_zpsa47b6527.jpg
Pwraddr is offline
Old 01-24-2014 | 02:34 PM
rrentsch's Avatar
Registered User
Went ahead and pulled the fridge to see what mine was like. My Vyper has no plywood under the fridge. The area where factory installed Depth transducer is open. The transducer looks like it is recessed into the bottom glass, the top is even with the inside glass. It does look like that the area around the transducer is a 1/4" to 3/8" thicker than the glass ahead of it. If I try to install the new transducer just ahead of the existing one, does anybody know if the bottom is solid glass there on the PQ's
rrentsch is offline
Old 01-24-2014 | 04:10 PM
Take a razor blade and cut the silicone around the transducer and pry it out..install the new transducer in original location..if you install it elsewhere it will not work because the hull is balsa cored.
boatnt is offline
