-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Big rectangle blemish in hull of 290 enticer... (https://www.offshoreonly.com/forums/powerquest/311387-big-rectangle-blemish-hull-290-enticer.html)
290enticer 04-23-2014 09:00 PM
I have a 90 enticer that is in great shape for its age and had had no major glass repair that I know of. I noticed this several years ago and seems to be getting more noticable as time goes on...Nobody else sees it though. It is on the port side right under the fuel tank fill, its about 5' long and prolly 12-15" thick. It appears to be a perfect rectangle with rounded edges...you have to look down the side and you will see it, you can't feel it and no glass work has been done, I have looked back behind on the inside...I dont know if this area was layed up differently in the mold or what but it always real shinny like its got the "wet" look when the rest of the boat gets "ashy" when it needs to be waxed..this area is always perfect..It hasnt been painted and all graphics are in gel coat. Has anyone seen this kind of thing on these boats??
speedreeder 04-23-2014 10:50 PM
I have a '94 and there are several others in my area. I have not noticed anything on mine, But it sounds like it was a factory repair before it left. I know you can see up inside there and maybe put a bright light on the outside and see if you can see any type of glass work or anything different from the inside. Good luck with it.
boatnt 04-24-2014 10:00 AM
sounds like a repair with clear over it
Knot 4 Me 04-24-2014 12:38 PM
Buddy has a '97 Enticer with a blemish in the same area. Looks like a prior repair.
