Go Back  Offshoreonly.com > Owners Forum > Powerquest
270 laser transom thickness? >
Old 04-28-2014 | 07:27 AM
Default 270 laser transom thickness?
Having to replace the transom in my 270 laser. Wood was so rotted that I could not get an accurate measurement of the plywood thickness. Anyone know what the ply thickness should be and the overall thickness when glassed? Thanks.
llibkore6 is offline
Old 04-28-2014 | 09:50 AM
It should be about 2 1/4" for a standard Merc Bravo
you need 2- 4x8 -3/4" sheets of 7 ply some say marine some say exterior house plywood,,if its sealed good I do not think it matters,but you use what you are comfortable with it..
boatnt is offline
Old 04-28-2014 | 10:54 AM
vintage chromoly's Avatar
[HR][/HR]I used 3/4 inch birch plywood. Cabinet grade.
Two layers.
vintage chromoly is offline
Old 04-29-2014 | 06:31 AM
Thanks guys.
Old 04-29-2014 | 06:42 AM
2 1/8 is the standard....max of 2 1/4. We stick to the 2 1/8 for the best alignment of the driveshaft on all our transom work and prefer 3 layers of 1/2" glassed together.
brian41 is offline
