340 Vyper
Decent boat. Few things: some bubbling in the paint along the water line on both sides (appears to be just on the surface), only a couple of small scuffs on the rest of the hull. Interior has a couple small tears, cabin carpet could use replacing, tv doesn't work, but all other electronics worked when he put it away last winter (batteries aren't back in yet), engine compartment is clean. The engines are very clean, but I think they aren't original (has msd ignition, among other things). Hour meters only read 200, assuming they aren't original either. Trailer is in good shape, but definitely needs tires. Overall a day or two of some good elbow grease and it would clean up nicely.
Pwraddr - sent you a PM
It, IMO, is very rough which is indicative of the care. It sits in the water all summer (I live near the boat). New motors with 200 hours on the boat also says a lot about the care.
If you are going to move forward just suggest you do so with eyes wide open.
But it will depend on what condition you want the boat to come back to.
