Go Back  Offshoreonly.com > Owners Forum > Powerquest
1988 powerplay 185 mcgill throttle rocker switch >
Old 08-01-2014 | 07:11 PM
Default 1988 powerplay 185 mcgill throttle rocker switch
Looking for a mcgill no/nc mcgill roller switch for a 1988 powerplay 350 mag. switch went bad and has no numbers just the mcgill name. Its the switch that comes off the distributor cap to the switch by the throttle cables.
powerplay185 is offline
Old 08-02-2014 | 01:07 PM
Ing's Avatar
Ing
Veteran: Marine Corp
I think you meant to post this thread under Powerplay and not Powerquest.
Ing is offline
Old 08-02-2014 | 02:35 PM
spazboz's Avatar
Ing, this would be the correct forum. This boat was produced here in Holland, MI by the company you may better know as Powerquest. In thier earlier years when they were known as Powerplay.
Powerplay185, are you referring to the neutral safety switch in the throttle assembly, or the interupt switch on the shifting plate? Nick
spazboz is offline
